Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 02 2:40 am)
Usually you don't have to INJ Morphs ++ first, I don't have this product, but the Uncle Albert INJ should call the morphs++, load & set him up, you shouldn't need to set a dial, usually it is automatic.
Do any other characters INJ properly? Maybe you need to reinstall Morphs++. Did you run the initialization script after installing Morphs++?
The best & most beautiful
things in the world cannot be seen nor touched... but felt in the
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
Quote - There should be a dial labeled Uncle Albert in the parameter panel where you can apply the morph.
He already said quite clearly that using the dial didn't help!
I really suspect it is because Morphs++ hasn't been initialized
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
Before you inject the Morphs++, you should see an empty Morphs++ container under Morphforms in your figure's body parameters. If it's not there, Anniebel is right and you did not initialise your M4 figure after installing the Morphs++ product.
After you have injected Morphs++, the container should now be populated with the Morphs++ parameter dials, as in my screen shot (yes, that's V4.2, but it works the same way). If it's still empty, there is something going wrong with the Morphs++ injection, which I personally would try to sort out first, before injecting the character.
If the Morphs++ dials show up correctly, and work when you twiddle them, I would suspect the character package itself, and contact the vendor for help.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
sambucus
try this zero/restore your m4 , all your morph dials.
then only move the uncle morph dial,
you should get the intended character if you set it to 1. again and get the same thing,
dial it back down. as the above pic looks over done
also check that the eye bags, ect.... morphs in ++ are not over dialed
as the daz promo pic doesn't look like yours.......lol
he seems to be melting..lol
