Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
[ X ] "Bend Body Parts" <<< You prolly need to do this.
It's on the main menu under "Display" >>> "Bend Body Parts"
There is, also, a [X] Bend for each Body Part in the "Properties" window under [X] "Visible".
If these do not fix your problem, you may need to "weld" the body parts.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
The thing about the shoulder breaking off sounds like a missing WELD parameter to me. Poser needs all groups welded :)
I'm a 3D modeler, and I'd like to rig some of my models for Poser, so that I can put them on the marketplace, and maybe even a freebie here and there.
My problem is that after I get the bones set up in Poser and I bind them to the model, parts of the poly-mesh break up as I pose it. The shoulder will tear right off the arm, and so on. Some of this appears to be because of the grouping, which I can work on, but some just seems wrong.
If anyone has experience rigging models in Poser, could you give me some tips to fix this?
Thanks!
