Thu, Dec 26, 7:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 7:45 pm)
Subject: Model rigging
fiction2002 ( ) posted Tue, 17 February 2009 at 11:44 AM · edited Thu, 26 December 2024 at 7:53 PM
I'm a 3D modeler, and I'd like to rig some of my models for Poser, so that I can put them on the marketplace, and maybe even a freebie here and there.
My problem is that after I get the bones set up in Poser and I bind them to the model, parts of the poly-mesh break up as I pose it.  The shoulder will tear right off the arm, and so on.  Some of this appears to be because of the grouping, which I can work on, but some just seems wrong.
If anyone has experience rigging models in Poser, could you give me some tips to fix this?
Thanks!
geep ( ) posted Tue, 17 February 2009 at 12:10 PM · edited Tue, 17 February 2009 at 12:11 PM
[ X ] "Bend Body Parts"  <<< You prolly need to do this. 😄
It's on the main menu under "Display" >>> "Bend Body Parts"
There is, also, a [X] Bend for each Body Part in the "Properties" window under [X]  "Visible".
If these do not fix your problem, you may need  to "weld" the body parts.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
fiction2002 ( ) posted Tue, 17 February 2009 at 12:14 PM
Thanks for that!  It's already set, though.  Some of it clears up when I tweak the grouping, but not all of it.  For instance, I have an upper arm with the bone grouped perfectly to that upper arm geometry.  When I bend it, the mesh tears at the shoulder and underarm.
Any other ideas? :-)
fiction2002 ( ) posted Tue, 17 February 2009 at 12:55 PM
I did some digging around on the 'net, and found this:
http://my.smithmicro.com/tutorials/44.html
I think this will take care of it for me, and possibly help others.  If I still have problems, I'll post them here.
markschum ( ) posted Tue, 17 February 2009 at 1:22 PM
You have sets of inclusion and exclusion zones and the spherical falloffs for each joint.  There is a bend paparamter on the body part properties display.
TrekkieGrrrl ( ) posted Tue, 17 February 2009 at 4:12 PM
 The thing about the shoulder breaking off sounds like a missing WELD parameter to me. Poser needs all groups welded :)
