Tue, Nov 26, 12:20 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 24 6:27 pm)
Subject: Creating shadows.
thekingtut ( ) posted Tue, 24 February 2009 at 7:52 PM · edited Mon, 11 November 2024 at 10:05 AM
I'm new to DS, and am wondering, how do I create shadows? It doesn't matter how good an image I produce, if it has no shadow, it just looks wrong.
mishamcm ( ) posted Tue, 24 February 2009 at 7:59 PM
To have shadows in D|S you need 3 things:
--a light source that has shadows turned on
--an object that casts shadows
--a surface to receive the shadow
Light sources are often set to "no shadow" by default to reduce render times, so you should make sure you have at least one light with shadows enabled.
Most objects (unless they aren't opaque) cast shadows by default, but they can be turned off.
Most objects receive shadows by default, but backgrounds do not.
If you have all 3 of these and still aren't getting shadows, make sure the light source is pointed the right way and not blocked by another object, and that you are using either software (3delight) rendering or a hardware (OpenGL) rendering that has shadows (if the latter, your grapjhics card must support OpenGL shadows).
thekingtut ( ) posted Tue, 24 February 2009 at 8:27 PM
Thanks, you're a great help.
darman42 ( ) posted Thu, 26 February 2009 at 10:57 PM
also, setting the lights to "deep shadow map" or "raytracing" will make better shadows.
warning!!!
using these settings WILL tax your computer and slow down render times. if you can accept that, though, the payoff is often worth it.
thekingtut ( ) posted Fri, 27 February 2009 at 5:08 PM
Yeah, I found those settings when I when into the parameters for the lighting. Thanks for the help though.
