Fri, Nov 22, 9:02 PM CST
Subject: different versions and the natural order
donquixote ( ) posted Wed, 04 March 2009 at 10:34 AM · edited Fri, 22 November 2024 at 3:44 PM
I know you can have different versions of Poser installed on the same system at the same time, but I don't know if this is true of all versions or if the order of installaton might be a factor.
I currently have Poser 7 installed. I would like to install my old versions, i.e., 6, 5, and perhaps even 4, for testing and compatibility purposes. Has anyone done this? Has anyone done this in something other than the natural lesser-to-greater order?
Were there any tweaks necessary? And does everything work okay?
Thanks.
donquixote ( ) posted Wed, 04 March 2009 at 10:35 AM
Oh yeah, I almost forgot. My OS is Vista 64-bit, which may be a factor ...
JenX ( ) posted Wed, 04 March 2009 at 10:37 AM
I have posers 5-7 currently installed :)  Works just fine.
ockham ( ) posted Wed, 04 March 2009 at 10:54 AM
Nope, the order doesn't matter.  I've installed 4,5,6,7 in all kinds of sequences,
and they always get along.
Unlike %#$%#^^&&%&$^%@%#%# Vista.
My python page
My ShareCG freebies
cspear ( ) posted Wed, 04 March 2009 at 12:13 PM
Poser installs are always self-contained: they don't put DLLs and stuff anywhere other than in the Poser X folder. This means you can install onto your C: drive, then move the entire folder onto another drive, and it'll still run.
You could even move it onto another PC, though this may cause problems depending on the configuration of the two systems.
You can certainly have different versions installed on the same system: I have versions 6, 7 and PoserPro all running nicely on my setup.
PoserPro 11 - Units: Metres
Adobe CC 2017
svdl ( ) posted Wed, 04 March 2009 at 12:51 PM
I'm not sure whether Poser 4 will install at all under Vista64, but installation order for 5,6,7 and Pro doesn't matter - except for one little thing. File associations. The .pz3 (and .pzz) extensions will be associated with the last install of Poser, not with the most modern.
My gallery   My freestuff
TrekkieGrrrl ( ) posted Wed, 04 March 2009 at 4:47 PM
Poser 4 (and later) will run from a CD or a USB flash if needed. I've done both several times. I've even tried it from an SD card. Works fine!
And all versions run just fine in Vista. At least the 32 bit Vista, I haven't tried the 64 bit version.
donquixote ( ) posted Wed, 04 March 2009 at 6:06 PM
Thanks all! Greatly appreciated!!
