Sat, Jan 11, 4:24 PM CST
Subject: A problem with arms
yapaplukon ( ) posted Tue, 10 March 2009 at 8:44 AM · edited Sat, 11 January 2025 at 1:01 PM
Hello,
I have a big problem with V4 and her arms... As soon as i apply a V4 pose and some lights, the arms break and give me this :
Any idea ?
Thank you
pjz99 ( ) posted Tue, 10 March 2009 at 8:54 AM
Look in the contents of the pose file that produces that problem, and see if undesirable channel info may have been included - specifically "translateX/Y/Z" parameters.
My Freebies
yapaplukon ( ) posted Tue, 10 March 2009 at 8:58 AM
Thank you but where do i see such thing, please ?
Adom ( ) posted Tue, 10 March 2009 at 9:46 AM
On your HD find the pose you applied and open it in text editor (should be in yor poser/runtime/libraries/pose/..... the file will have the same name which you can see under the thumbnail in POser + extension pz2 = filename.pz2)
Then (inside editor) look for the actor (bodypart) which gives the problem - the names are not exactly the same like for real human.
When you find it look for lines with: translateX, translateY, translateZ - normally they shouldn't be there but like pjz99 said they can. In case you find them then just remove or make them 0.
pjz99 ( ) posted Tue, 10 March 2009 at 11:10 AM · edited Tue, 10 March 2009 at 11:11 AM
...or possibly go back to the source you got them from and ask for either a correction, or a refund if you paid money for them.  The only things that should ever be saved into poses - that is, poses that actually POSE the character, as opposed to utility poses that apply materials or some such - are joint rotations, with the sole exception of hip translations.  Expressions are a small exception, but those ought to be separate files again.
My Freebies
markschum ( ) posted Tue, 10 March 2009 at 11:18 AM
Is this happening with a specific pose /set/ or any v4 pose ?   If any v4 pose you may need to reinstall v4 and the morphs.
yapaplukon ( ) posted Tue, 10 March 2009 at 11:22 AM
Actually, this is a freebie pose pack i found... I cannot ask for anything i guess  :-)
The Lines you told me to look for were there with the value 0...  :-(
I deleted them to see the result but it gave me the same thing...
Anyway, thank you to both of you
pjz99 ( ) posted Tue, 10 March 2009 at 11:27 AM
Do you ever get this kind of problem when you manually pose the figure?  If not, then the problem is certainly with those specific poses - junk em if so, or you could poke around some more and pick out whatever screwed up data is in there and try to clean it out.
My Freebies
patorak ( ) posted Tue, 10 March 2009 at 11:29 AM
That would be an excellent pose for a trauma victim.
yapaplukon ( ) posted Tue, 10 March 2009 at 11:42 AM
Quote - Do you ever get this kind of problem when you manually pose the figure?  If not, then the problem is certainly with those specific poses - junk em if so, or you could poke around some more and pick out whatever screwed up data is in there and try to clean it out.
I have tried to do so... It seems nothing happens... Then the poses pack is in the trash bin
I stop free poses then.
Thanks a lot
yapaplukon ( ) posted Tue, 10 March 2009 at 11:43 AM
Quote - That would be an excellent pose for a trauma victim.
LMAO . . . Then all my characters have a trauma :-) :-) :-)
pjz99 ( ) posted Tue, 10 March 2009 at 11:43 AM
Well, there are lots of free poses that are OK, and (very sadly) lots of commercial poses that are not so OK.  ;)
My Freebies
Morkonan ( ) posted Tue, 10 March 2009 at 6:34 PM
Quote - Hello,
Any idea ?
Thank you
Doublecheck to see if the pose has changed any scaling.  Sometimes, it seems that poses that aren't made for a figure will end up changing a scale value.  I suppose since Poser doesn't know where to put the value, it randomly decides to muck with the scaling.   If all the scale dials aren't showing, download "unhide parms" http://www.ockhamsbungalow.com/Python/ from Ockham and apply it to the figure to reveal the translate/scale dials.
PS - Make sure IK is turned off.  Sometimes, that has weird results when applying poses.
Morkonan ( ) posted Tue, 10 March 2009 at 6:36 PM
Quote - Well, there are lots of free poses that are OK, and (very sadly) lots of commercial poses that are not so OK.  ;)
I especially love poses that re-zero all your hard-spun morph values and custom morph targets... those are great!  Really... they're lots of fun... yeah..  honest...  true story...
patorak ( ) posted Tue, 10 March 2009 at 7:48 PM
*I especially love poses that re-zero all your hard-spun morph values and custom morph targets... those are great!  Really... they're lots of fun... yeah..  honest...  true story...
LOL!  You know I had a project that was wiped out by one of those poses.
ThrommArcadia ( ) posted Tue, 10 March 2009 at 10:40 PM
Morkonan and patorak  I hear you!
Yep, been there.  Commercial poses too!
I came to recommend what Morkonan said, so my work here is done.  No need to thank me. lol
patorak ( ) posted Tue, 10 March 2009 at 11:11 PM
*Morkonan and patorak  I hear you!
I came to recommend what Morkonan said, so my work here is done.  No need to thank me. lol*
Yep!  Maybe these pose packages should come with a surgeon general's warning.
