Thu, Feb 13, 4:52 AM CST
Subject: Reinstalled Poser 7 and it still crashes...
magicmoondesigns ( ) posted Sun, 08 March 2009 at 6:39 AM · edited Mon, 29 July 2024 at 11:57 PM
Poser 7 was running fine until about a week ago when it started crashing whenever I would run PhilC's "Scissors".  Then it started crashing if I rendered with a separate process (if I got into the running processes the firefly render engine continues to run even though Poser has disappeared).  If I render without using a separate process, I seem to run a 75% chance of getting a message that Poser is out of memory and I should render in a separate process (which doesn't work either).
I completely uninstalled Poser 7 and reinstalled it but SR1 and SR2 are no longer available to download so I had to install SR3 (grr).  I thought doing a reinstall of Poser would fix whatever went wrong but I'm still having the exact same problems.  I'm running Windows XP and all of my drivers are up to date...any suggestions on how to correct this would be most appreciated.
Vickie
TrekkieGrrrl ( ) posted Sun, 08 March 2009 at 6:48 AM
 Now.. my problem occurred in Vista and not XP, but just to aliminate the video driver as a possible culprit, try switching preview modes to SreeD and see if the problem persists. If this fixes it then it's definitely something wit the OpenGL driver and you should check for an update of your video driver.
If it keeps crashing after this, then it's something else...
When you installed it, did you install it on top of the existing Poser or in a new location?
IsaoShi ( ) posted Sun, 08 March 2009 at 7:11 AM
Before you re-installed Poser, you should make sure to get rid of any leftovers of the previous installation, by deleting the whole Poser 7 folder.
If you have content in there that you don't want to lose, by all means take a backup copy of the folder first... but that folder should be completely deleted before a fresh install.
Hope it helps...
Jules53757 ( ) posted Sun, 08 March 2009 at 7:24 AM
If nothing helps, look into the Poser settings folder, usually to be found in c:Documents and SettingsYour_NameApplication DataPoser 7 and rename the LibraryPrefs.xml and the Poser.ini.
Maybe the path is not correct as I'm running windows in a German version but ist should be something like the above stated.
Ulli
magicmoondesigns ( ) posted Sun, 08 March 2009 at 1:35 PM
I did delete the Poser 7 folder before reinstalling, so that isn't the problem.  The problem isn't with my video drivers, as I said I did check that before.
IsaoShi ( ) posted Sun, 08 March 2009 at 4:20 PM
Okay, so it does not appear to be a problem with the Poser installation, or with your video card, is what you seem to be saying.
It might just be a memory problem (unless you also run other applications that  use as much memory as Poser and they work fine). To eliminate this possibility you can run the Windows memory diagnostic utility. You will need to download this from the Microsoft web site and create a bootup CD.
The only other thing I can suggest is to think back to what you changed just before it started playing up, and try to undo it... perhaps by going back to a System Restore point from before it started misbehaving. You do have System Restore points.... don't you? :O)
ThunderStone ( ) posted Sun, 08 March 2009 at 8:06 PM
What brand video card do you have installed?
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
TrekkieGrrrl ( ) posted Sun, 08 March 2009 at 9:22 PM
 Now.. I'm just silly and all.. but did you ever try to change the preview mode? Just to ELIMINATE the possibility of this being OpenGL related?
There was a new NVidia driver out this week. So ... well. You have the latest drivers of course. But it's still worth investigating the possibility of an OpenGL issue - and that is easily done by changing to the non-OpenGL SreeD preview.
magicmoondesigns ( ) posted Mon, 09 March 2009 at 7:03 PM
I found the solution to the problem at another site.  My anti-virus software was picking up a Poser process as being a Trojan and was refusing to let it run.  Unfortunately the window that said it was blocking a process was coming up behind Poser so I couldn't see it to tell it to knock it off ;-)
ThunderStone ( ) posted Mon, 09 March 2009 at 8:26 PM
Quote - I found the solution to the problem at another site.  My anti-virus software was picking up a Poser process as being a Trojan and was refusing to let it run.  Unfortunately the window that said it was blocking a process was coming up behind Poser so I couldn't see it to tell it to knock it off ;-)
What site and what was the solution?
nyguy ( ) posted Tue, 10 March 2009 at 11:32 AM
I had this same issue when I would run any python based program. I had contacted my AV maker and they told me how to get it working with a few "tweaks"
Poserverse The New Home for NYGUY's Freebies
ThunderStone ( ) posted Tue, 10 March 2009 at 11:49 AM
nyguy what your av maker and what is the site?
