Mon, Feb 17, 12:09 AM CST
Subject: Error in VUE
IronHorse61 ( ) posted Wed, 11 March 2009 at 4:01 PM · edited Sun, 16 February 2025 at 11:57 PM
I use Vista Home 64-bit, I get occasiounally error when I close program. But now I can´t start at all It says SendLog.exe error ?  Any idés
bruno021 ( ) posted Wed, 11 March 2009 at 4:24 PM
Not sure I understand what you mean. You can't open Vue anymore?
What window says Sendlog.exe?
The sendlog.exe is the automatic error report Vue launches after a crash so you can send a report to e-on. The report contains the text you will enter in the error report's window, and an automatic crash log that was created after the crash.
IronHorse61 ( ) posted Wed, 11 March 2009 at 4:36 PM
VUE can´t prepare the error log?  It says "Something went wrong while trying to prepare an error log for your e-on application"  Only way for me to start VUE again is to make a system restore to a point before this error accured....?
bruno021 ( ) posted Wed, 11 March 2009 at 7:08 PM · edited Wed, 11 March 2009 at 7:09 PM
Wow! Never heard of this one. What is your OS? Maybe you could simply delete the report and see if Vue wants to start.
By the way, is it a Vue message, or a message from your OS?
hein ( ) posted Wed, 11 March 2009 at 11:37 PM
Vue 7 has build-in error reporting  (see page 34 of the ref. manual) that uses sendlog.exe.
IronHorse61 ( ) posted Thu, 12 March 2009 at 4:54 AM
I think the error log is generated by VUE, just like hein said. As It is now I can only start VUE one time after system restore. Second time I start, I end up with the same message again. I have found SendLog.exe in two folders, but I can´t do anything with them. Sometimes two error dump files are created, but even if I delete them I end up with same problem.. Maybe there are some way to disable the error report from within VUE ?
bruno021 ( ) posted Thu, 12 March 2009 at 5:35 AM · edited Thu, 12 March 2009 at 5:36 AM
No, this is automatic. Even if you don't authorize the sendlog.exe to send data from your firewall, it will popup anyway and create the crash log.
IronHorse61 ( ) posted Thu, 12 March 2009 at 6:47 AM
So what would be the conclusion? Shall I reinstall the sofware and hope that any broken files will be replaced and register cleaned!
bruno021 ( ) posted Thu, 12 March 2009 at 7:40 AM
Think so, yes...
Vesto ( ) posted Thu, 09 April 2009 at 2:59 PM
Hi!
If I don't late (sorry for my English). You should delete file "Vue 7 xStream.reg" in WINDOWS folder. After that you could re-install VUE....
