Sat, Feb 1, 9:26 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: problem with inserting a vertex object in C7.1.1 Pro
Xerxes0002 ( ) posted Sat, 21 March 2009 at 7:09 PM · edited Sat, 01 February 2025 at 9:25 AM
It hangs if I do an insert vertex object, it also will hang when I attempt to edit a vertex object.
Whole story:
I have C6 Pro and installed C7 Pro and then 7.1.1 update.
I was attempting to do jetbirds modeling katis character tutorial. I had an empty new scene and inserted a vertex object and C7 Pro locked up. I restarted the computer, tried it again same thing, I let it sit awhile in case it needed to work something out. Eventually had to kill the app.
I reset the preference just in case.  I wiped the tmp files also.
I tried in C6 Pro and it worked fine.
I did the Fruit and Bowl tutorial a little while back with just C7 Pro (not the 7.1.1 update) and things where working fine. I was able to go into the vertex room and do the section on a vertex object for the tutorial just fine. Now that I have 7.1.1 Carrara Locks up when I try to go into the vertex room with the same file.
Any suggestions before I open a bug report, I figured its something here on this machine, if this was a general bug in C7.1.1 then everyone would be screaming but I can't seem to get around it, and am dead in the water using C7.
GKDantas ( ) posted Sat, 21 March 2009 at 9:44 PM
I had a lot of model and videos using 7.1.1 (one new today about model inVM room) and didint get this error. Since version 7 has a new openGL engine (a better one), do you have your video drives updated?
Try to add a primitive and convert to VM to see whats happen too... very weird thing...
Follow me at euQfiz Digital
Xerxes0002 ( ) posted Sat, 21 March 2009 at 10:56 PM
Quote - I had a lot of model and videos using 7.1.1 (one new today about model inVM room) and didint get this error. Since version 7 has a new openGL engine (a better one), do you have your video drives updated?
I updated my video drivers a little while back, before I had done the fruit bowl tutorial.
I did that with the primitive and convert to Vertex in the modeling room soon as I told it to convert it locked up.
There is a slight version update from Nvidia I am going to try, to see if it makes a difference.
It locked up Carrara Hard, and I have to have windows kill it.
I will post if the new drivers made a difference.
-Milo
Xerxes0002 ( ) posted Sun, 22 March 2009 at 1:46 AM
Update:
I installed the latest video drivers and it made no difference.
GKDantas ( ) posted Sun, 22 March 2009 at 8:26 AM
I think that next step is to install Carrara again...
Xerxes0002 ( ) posted Sun, 22 March 2009 at 10:39 AM
just tried that, still the same thing.  I am going to have to go back to 7.0  I submitted a bug report though don't know what good that will do.  is yours 7.1.1 or 7.1 in the about box?
GKDantas ( ) posted Sun, 22 March 2009 at 11:19 AM · edited Sun, 22 March 2009 at 11:19 AM
In the Splash screen at startup.
Xerxes0002 ( ) posted Sun, 22 March 2009 at 7:19 PM
Thanks
I am really hosed now.  I went back to 7.0 and the exact same thing, even the file I worked on before now no longer works.
I simply cannot go into the modeling room with a vertex object.
So its not 7.1.1 but now I am at a total loss as to what to do.  I made sure my drivers where the latest nvidia ones.
The application hangs, shows CPU pegging on one of my cores.
anyways there is the update.. I will update the bug report as well
Xerxes0002 ( ) posted Mon, 23 March 2009 at 2:06 AM
I think since the extensions are version dependent there should be some kind of check.
GKDantas ( ) posted Mon, 23 March 2009 at 3:14 AM
Do you have a plugin outdated?
Thelby ( ) posted Mon, 23 March 2009 at 11:03 AM
So far I have not been able to get anything worth while out Carrara7 Pro. I keep getting Memory Alocation Errors from some of the lightest scenes. I think the whole thing needs serious work on DAZ's part. I will continue with 6 Pro until something is done with 7 Pro. Just my thoughts and experience expressed here, so I don't think you have done anything wrong or that it is your drivers.
I would rather be Politically Incorrect,
Then have Politically Correct-Incorrectness!!!
Xerxes0002 ( ) posted Mon, 23 March 2009 at 2:24 PM
Quote - Do you have a plugin outdated?
I think that was it, these are the 3 that i pulled out effectively that were 'left' over from un-installs. The shoestring shader is a beta, so I will see if there is another out there.
01/10/2009  10:15 PM           241,664 Cloth.mcx
12/02/2008  07:10 PM         2,859,008 Shoestring_shaders.mcx
01/09/2009  10:47 PM           180,736 SimpleLightingModel.mcx
so I will dig some more on those and see about the updates.  I could check to see which one it is thats doing it if anyone is curious.
Thanks again for letting me bounce things off and the suggestions.
Xerxes0002 ( ) posted Mon, 23 March 2009 at 2:26 PM
Quote - So far I have not been able to get anything worth while out Carrara7 Pro. I keep getting Memory Alocation Errors from some of the lightest scenes. I think the whole thing needs serious work on DAZ's part. I will continue with 6 Pro until something is done with 7 Pro. Just my thoughts and experience expressed here, so I don't think you have done anything wrong or that it is your drivers.
I am sorry to hear that you are having those problem, so far I haven't had any of that and it turned out my problem was a bad plugin.
Thelby ( ) posted Mon, 23 March 2009 at 2:47 PM
@ Xerxes0002
Yeah, me too. I spent the money for the upgrade because I really like Carrara and  now I am back to using 6 Pro. But on the bright side 6 Pro is almost flawless on my system and it is what I learned to use Carrara with, so it is the old glove that fits so well.
GKDantas ( ) posted Mon, 23 March 2009 at 3:03 PM
I had one big problem in the render one time... I simple moved all my plugins (added after installation), and have to copy one by one back until find what plugin was causing all the problem. Now everything works fine, I found the plugin that slowdown the system.
Xerxes0002 ( ) posted Mon, 23 March 2009 at 6:02 PM
good idea.. I put the shoestring ones back and it wasn't the culprit at least.
