Sat, Jan 25, 11:30 AM CST
Subject: How do I get rid of unwanted images maps?
moonwatcher ( ) posted Sun, 29 March 2009 at 5:38 PM · edited Fri, 10 January 2025 at 5:08 PM
I’m using Poser 7 and I have these unneeded image maps, they are the result of trying this and trying that. When I finally found a combination I liked I deleted some of the files that where associated with them. Now whenever I open this file Poser asks for me to fined the delete files (very annoying). Is there some way I can delete these unneeded image maps?
geep ( ) posted Sun, 29 March 2009 at 5:46 PM · edited Sun, 29 March 2009 at 5:49 PM
Hold down the Contol (Ctrl) key and click on the ones you want to delete so thay are selected.
Now right click and select "Delete"
All gone. 😄
Caution- :scared:
Make sure you don't have any that you want to keep "selected" before you click "delete."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Believable3D ( ) posted Sun, 29 March 2009 at 5:58 PM
Or, if you're sure all your wanted nodes are attached, click open the slider on the right hand of the material room interface, and select Remove Detached Nodes.
______________
moonwatcher ( ) posted Sun, 29 March 2009 at 6:13 PM
Thanks geep and Believable3D, Both your tips work real well!  Don't I feal blind I did not see "Remove Detached Nodes" until now.
Believable3D ( ) posted Sun, 29 March 2009 at 7:18 PM
Not to worry. I closed that slider early on in my work in the material room and forgot about it. Somebody else just pointed that same feature out to me last week.
:blushing:
______________
hborre ( ) posted Sun, 29 March 2009 at 9:10 PM
Online Now!
And if you read the fine print on the bottom, to remove all unattached nodes in your model hold shift and press "Remove Detached Nodes".
infinity10 ( ) posted Sun, 29 March 2009 at 10:32 PM
Online Now!
An extension of this discussion:
Sometimes, the material shader panels which are undetached, are hidden out of view because of the limited size of the material room window.
I find that I need to scroll right or scroll down ( if the scroll bars appear inside the Materail Room window ) to check.
Eternal Hobbyist
