Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Hold down the Contol (Ctrl) key and click on the ones you want to delete so thay are selected.
Now right click and select "Delete"
All gone.
Caution- :scared:
Make sure you don't have any that you want to keep "selected" before you click "delete."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Or, if you're sure all your wanted nodes are attached, click open the slider on the right hand of the material room interface, and select Remove Detached Nodes.
______________
Not to worry. I closed that slider early on in my work in the material room and forgot about it. Somebody else just pointed that same feature out to me last week.
:blushing:
______________
An extension of this discussion:
Sometimes, the material shader panels which are undetached, are hidden out of view because of the limited size of the material room window.
I find that I need to scroll right or scroll down ( if the scroll bars appear inside the Materail Room window ) to check.
Eternal Hobbyist
