Tue, Nov 19, 7:39 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: an idea for a network rendering script.
Khai ( ) posted Wed, 01 April 2009 at 10:14 AM · edited Tue, 19 November 2024 at 5:22 AM
ok, this may take some explaining.. please bear with me.
with PoserPro's network rendering, it works on full frames only. you can't send 1 image (frame) to mulitple nodes to render sections of the image to speed up one image.
so I was thinking,
what if you set up a script that would say split a render down into frames?
I'm thinking the script on frame one would use say a black plane to mask off the left half of the image. then on frame 2, the mask would flip and mask off the right side. - using the masks would also keep the image size constant over the renders.
then these could be sent to 2 nodes to render and could be recombined easily into the one image (the idea could be taken further with the masks to split down to say 4 or more sections).
could someone A: check my logic on this (it feels right, but that don't mean a thing) and B: program it if it does work?
Khai ( ) posted Fri, 03 April 2009 at 9:25 PM · edited Fri, 03 April 2009 at 9:25 PM
19 views and not even a 'that won't work!'?
I know I posted it on april 1st, but I was being serious. it's not a joke post!
nruddock ( ) posted Sat, 04 April 2009 at 5:03 AM · edited Sat, 04 April 2009 at 5:05 AM
I suspect that most (if not all) of the people of who do PoserPython don't have a render farm and/or more than one license, so beyond testing with a single node to see if there's a time saving, there's probably not much anyone can do as most of the programming effort for farming is in the scatter/gather.
How about you do a few trial renders to see if there is a time saving.
markschum ( ) posted Sat, 04 April 2009 at 10:31 AM
I dont have Poser pro or even two pc to test with. I did do a script once for a batch renderer, not very robust if Poser fails in a render though.  I could see adding a prop for a camera mask , with material zones to make opaque or transparent to set which quadrant was rendered.   Is there a poser pro python manual ? how do you access a remote renderer ?
