Mon, Feb 3, 8:42 AM CST
Subject: Lace Trims
ladyperiwinkle ( ) posted Tue, 07 April 2009 at 9:13 AM · edited Mon, 03 February 2025 at 8:40 AM
How do add lace trims to clothing -- Like if I have a dress and I want the middle of the dress to be lace and not regular material -- how would I do that.
Thank  you!
FredaF ( ) posted Tue, 07 April 2009 at 10:22 AM
 you have to make a uv map of the dress (if you dont have one yet) and make a custom texture with the lace parts on it where you want them, then make a transparent map with the transparent parts of your lace black and the covered parts white and add all textures in the material room,
good luck, Freda
ladyperiwinkle ( ) posted Tue, 07 April 2009 at 10:33 AM
How do you make UV maps?
SSAfam1 ( ) posted Tue, 07 April 2009 at 10:38 AM · edited Tue, 07 April 2009 at 10:39 AM
Attached Link: Making Textures
> Quote - How do you make UV maps?
Did you check in your texture folder to see if you already have the template for the clothes?
Attached is a mini clothing texture tutorial. The very first image is what a template looks like. Also at the link is UV Mapper. The utility you'd need to make a template.
ladyperiwinkle ( ) posted Tue, 07 April 2009 at 6:47 PM
Thank you for your help!
TrekkieGrrrl ( ) posted Wed, 08 April 2009 at 8:15 AM
The easiest way is to use Poser's Grouping tool and select the polygons you want to be lace, then assign a new material for those (call it lace or whatever you like :) )
Then assign some lace texture and -transmap to your new material zone :)
This is assuming the cloth in question is already UVMapped (most are).
Daidalos ( ) posted Wed, 08 April 2009 at 12:07 PM
Trekkie what version of Poser does that?
"The Blood is the life!"
hborre ( ) posted Wed, 08 April 2009 at 3:43 PM
The Grouping Tool can be found in PoserPro, Poser 7, and IIRC Poser 6.
TrekkieGrrrl ( ) posted Fri, 10 April 2009 at 10:36 AM
 The Grouping tool is in Poser from at least 4 and upwards.
It's a much overlooked feature in Poser.
ladyperiwinkle ( ) posted Sat, 11 April 2009 at 7:59 AM
How does that grouping tool work, and do i work with it in the material room?
Thank you
TrekkieGrrrl ( ) posted Sat, 11 April 2009 at 1:09 PM · edited Sat, 11 April 2009 at 1:11 PM
 Here's a short tutorial. I used my morphing vase because I had that in Poser already but the principle is the same of course :)
Open the Grouping Tool. Your prop or dress will turn black. This is normal. Use the front camera for ease of selecting both sides in one go
Click "New Group" and call it whatever appropriate. The name doesn't matter.
In order to select both front and back at the same time, go to WIRE mode preview. This is optional but I find it convenient.
Select the polygons you want to have their own material by dragging the mouse over them. CTRL when hold deselects any stray polygons
Click Assign Material and give your material a name (in this case I named it stripe just as my temporary group)
In the Material Room you will now have a new material on your dress or prop or whatever. Assign an appropriate material to it. As you can see I wasn't taking enough care when selecting the polys because this was just a quick thing for this tutorial.
And that's it. This is how the Grouping Tool works :) Very easy.
ladyperiwinkle ( ) posted Sat, 11 April 2009 at 10:31 PM
Wow! thank you!
