Thu, Feb 13, 3:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 3:05 pm)
Subject: Best textures?
meltz ( ) posted Fri, 10 April 2009 at 9:44 PM · edited Thu, 13 February 2025 at 3:29 PM
What are some of the most realistic skin textures for vicky 3 and 4 ?
just looking for the best ones out there, also on other models as well.
Believable3D ( ) posted Sat, 11 April 2009 at 1:01 AM
Tricky question, as how realistic a texture appears is also heavily dependent upon the accompanying shaders. Then there's also the fact that a set may have a pretty much perfect diffuse (color) map but a horrible bump map... in such a case, do you say it's a great texture, or not?
______________
Anthanasius ( ) posted Sat, 11 April 2009 at 5:20 AM
Totally agree you can have a realy good texture but with a poor shader the texture appear poor ...
Génération mobiles Le Forum / Le Site
hborre ( ) posted Sat, 11 April 2009 at 7:23 AM
Nowadays, skin texturing relies heavily on shader node components in the material room to bring out realism.  Some are very intricate and elaborate, others are compact and fairly straight-forward.  With shaders, you can take a bad or mediocre skin texture and convert it into an amazing work of art.  Bagginbill's VSS Prop does that to any skin texture it is applied.
MysticDaniel ( ) posted Sat, 11 April 2009 at 1:49 PM · edited Sat, 11 April 2009 at 1:51 PM
you should check out shahara's and 3dreams' products. They are very realistic and look great on other characters too. You should try their "paul for v4" he's excellent!!
meltz ( ) posted Sun, 12 April 2009 at 8:59 PM
cool so is thre some good tutorials about shader nods and the material room so i can learn about making the renders look realistic?
also where can i find bagginbills vss prop, i looked but souldent find it anywhere.
Believable3D ( ) posted Sun, 12 April 2009 at 10:11 PM
This thread is a sticky at the top of the Poser forum here:
www.renderosity.com/mod/forumpro/showthread.php
The VSS stuff is available here:
http://poserbagginsbill.googlepages.com/vsshomepage
______________
hborre ( ) posted Sun, 12 April 2009 at 10:12 PM
This is the current link for the VSS Prop:
And this is the thread covering opinions, analysis and instructions.  Be prepared,  there are close to 100 pages on this topic and several other threads dealing with VSS related discussions.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2737823&page=1
