Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Tricky question, as how realistic a texture appears is also heavily dependent upon the accompanying shaders. Then there's also the fact that a set may have a pretty much perfect diffuse (color) map but a horrible bump map... in such a case, do you say it's a great texture, or not?
______________
Nowadays, skin texturing relies heavily on shader node components in the material room to bring out realism. Some are very intricate and elaborate, others are compact and fairly straight-forward. With shaders, you can take a bad or mediocre skin texture and convert it into an amazing work of art. Bagginbill's VSS Prop does that to any skin texture it is applied.
This thread is a sticky at the top of the Poser forum here:
www.renderosity.com/mod/forumpro/showthread.php
The VSS stuff is available here:
______________
This is the current link for the VSS Prop:
http://poserbagginsbill.googlepages.com/vsshomepage
And this is the thread covering opinions, analysis and instructions. Be prepared, there are close to 100 pages on this topic and several other threads dealing with VSS related discussions.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2737823&page=1
What are some of the most realistic skin textures for vicky 3 and 4 ?
just looking for the best ones out there, also on other models as well.
