DAZ|Studio F.A.Q (Last Updated: 2024 Oct 21 3:29 pm)
Density of cloud centers. Both Vue 7 Infinite and Carrara 7 Pro have such clouds. But you have to look at their renders and compare.
Here are two renders from Vue 7 Infinite using the same cloud: http://www.shonner.com/drafts/vue7_clouds.htm
3D and volumetric are different things. Both are 3D though. A cube of fog is not volumetric.
3D models as used by Poser are just empty shells. Use a simple primitive, like cube or sphere with texture and transparency to fake fog or clouds and only the outer surfaces effect the lighting. True volumetric means the model is treated as if it had volume, lighting will be scattered, defused and refracted by this volume, producing more realistic effects.
In Carrara, volumetric clouds look like frayed cotton balls. In Vue, volumetric clouds look like cotton balls that are clumpped together. These are the defaults in both apps and can be adjusted more so in Vue.
Can anyone tell me the difference between Volumetric clouds and regular ole clouds in 3D.
Please try to keep it a bit simple.
Thanks
