Tue, Feb 4, 10:04 AM CST
Subject: Using Texts in POSER 7
Eiseprod ( ) posted Fri, 17 April 2009 at 11:52 AM · edited Tue, 04 February 2025 at 10:00 AM
Hi all, is it possible to write and animate texts in Poser 7. If so how can I write something like '' HELLO WORLD!'
Thank you all.....
ice-boy ( ) posted Fri, 17 April 2009 at 12:02 PM
i think we can not model from scratch in poser. only import.  and combine props together.
but we can animate objects and move them around.
CaptainJack1 ( ) posted Fri, 17 April 2009 at 12:02 PM · edited Fri, 17 April 2009 at 12:02 PM
Depends on what kind of animation you want to do, but you can if you've got a mesh in the shape of text.
Wings 3D is a simple (and free) option for making text shapes, although they can be a right bear to UV map.
Do you want to just move the text around your scene, or do something more complex, like bending it in an arc?
Eiseprod ( ) posted Fri, 17 April 2009 at 1:15 PM
Bending it in an arc and also creating an effect of engraving in a box
animajikgraphics ( ) posted Fri, 17 April 2009 at 1:47 PM
To do those kinds of effects, you need a modeling app for that. Cararra 7 will do nicely for sure, but some other 3D modeling apps might work as well?  (Hexagon. wings3d. should work as well)
Poser is limited to animating position/scale/rotation of the imported obj files.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
ockham ( ) posted Fri, 17 April 2009 at 1:59 PM
Attached Link: Hansel & Gretel
If you want to animate the *motions* of writing, check out my Hansel and Gretel python script.
My python page
My ShareCG freebies
CaptainJack1 ( ) posted Fri, 17 April 2009 at 2:37 PM
If you want to animate it bending, I think your best option with Poser would be to rig a skeleton with bones coming from the middle of the text toward the edges, parallel to the baseline. You'd probably have to sub-divide the text a lot to keep it from crinkling. I don't think magnets would give you the control you'd be looking for.
If you just want it bent, I know Wings can do that. Then you could import it as a prop, move the hot point to where you want it, and rotate or  maneuver it.
Engraving in a model is difficult, because that would require subtracting one mesh from another, which is usually not good, except in the most expensive of modeling programs. A better choice for engraving would be to make a texture with the writing on it in the bump channel, or even displacement if you want it really deep. You'd have the option to create a 2D animation of your map (in some other, as yet unnamed program) and laying it down that way.
Eiseprod ( ) posted Fri, 17 April 2009 at 7:20 PM
Thank you all. I really appreciate all your responses
