Sat, Jan 11, 7:00 PM CST
Subject: Is it possible to play Quicktime videos in Windows XP pro 64 bit?
lululee ( ) posted Mon, 20 April 2009 at 12:12 PM · edited Sat, 11 January 2025 at 6:57 PM
Hi
Does anyone know if there is any kind of update that makes it Is it possible to play Quicktime videos in Windows XP pro 64 bit?
cheerio
lululee
animajikgraphics ( ) posted Mon, 20 April 2009 at 12:22 PM
Try Apple's site - if they don't have it on the main page for XP, try a search on their site, they usually have legacy versions available.
http://apple.com/quicktime/
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
lululee ( ) posted Mon, 20 April 2009 at 12:28 PM
Hi animajikgraphics,
     What is a legacy version?
cheerio  lululee
animajikgraphics ( ) posted Mon, 20 April 2009 at 12:44 PM
For an older OS
Navigate to the apple.com page (in my post above) to download quicktime using your 64-bit Internet Explorer.
Only then will you be able to download the 64-bit quicktime (it's still a 32-bit program, but it plays nice with 64-bit OS).  Hopefully this helps.
ghonma ( ) posted Mon, 20 April 2009 at 1:53 PM
Or you could just get quicktime alternative codec from here:
Quicktime Alternative
DarkEdge ( ) posted Mon, 20 April 2009 at 2:45 PM
Yes, absolutely.
I have Windows XP Pro x64 bit and can play Quicktime, AVI and WMP files....besides other types too. 😉
lululee ( ) posted Mon, 20 April 2009 at 3:17 PM
Hi,
Thanks everyone for the info.
I still cannot get Quicktime to play.
I tried installing both Quicktime and the alternative Quicktime.
Is it possible that I need to update my video drivers?
cheerio  lululee
ghonma ( ) posted Mon, 20 April 2009 at 9:26 PM
So what error do you get when you try to install (if any) or play the video? And what player are you trying to use ? Did you try that media player classic thing that alt. quicktime installs ?
Also note that you can't use any 64 bit player or tool to work with quicktime as it is 32 bits. Only 32 bit ones will work, even if you run them under XP 64.
lululee ( ) posted Tue, 21 April 2009 at 11:19 AM
Hi, Here is the error I get even though I have downloaded and installed quicktime. Quite frustrating. Grrrrr! Any help is truly appreciated. Cheerio  lululee
ghonma ( ) posted Tue, 21 April 2009 at 12:12 PM
Maybe this will help :
Error 2096
lululee ( ) posted Tue, 21 April 2009 at 1:07 PM
Hi ghonma,
  No cigar. It is not running in compatability mode. I have uninstalled, re installed etc.
Still it will not run.
Thanks for your help.
cheerio
lululee
Puntomaus ( ) posted Tue, 21 April 2009 at 7:44 PM
I have Quicktime installed on Vista 64 Business and it works fine. I didn't do anything special but just downloaded and installed.
Tucan-Tiki ( ) posted Tue, 21 April 2009 at 10:57 PM
you may need to get a quicktime update or the newest version.
nightfall ( ) posted Wed, 22 April 2009 at 1:29 AM
 Is your XP64 updated to SP2?
lululee ( ) posted Wed, 22 April 2009 at 7:07 AM
Hi,
nightfall,   I have the computer set to update every night. Would that get it to update to SP2?
Tucan Tiki I have updated the latest version that is on the Quicktime page.
cheerio
lululee
nightfall ( ) posted Wed, 22 April 2009 at 8:06 AM
Quote - Hi,
You can check the version by right-clicking My Computer->Properties.
lululee ( ) posted Wed, 22 April 2009 at 9:58 AM
nightfall, Here is what i get when I right click on the properties. i really appreciate all of your help. cheerio lululee
nightfall ( ) posted Wed, 22 April 2009 at 10:09 AM
Quote - nightfall,
cheerio
lululee
The screenshot says Service Pack 1.
You can get get XP64 SP2 from MS
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=893FD6C0-6283-44C3-BB84-B2F0315B2AE6&displaylang=en
](http://www.microsoft.com/downloads/details.aspx?FamilyId=893FD6C0-6283-44C3-BB84-B2F0315B2AE6&displaylang=en)Newer versions of quicktime requires XP SP2 and above.
Quicktime 7.3 is the last version that supports XP SP1 iirc.
lululee ( ) posted Wed, 22 April 2009 at 10:16 AM
Thanks so much nightfall.
I have very little system skills.
Once I have downloaded the update, is it ok to just click and install it?
I wonder why it did not get that update on it's own.
Again, I really appreciate your help.
cheerio
lululee
nightfall ( ) posted Wed, 22 April 2009 at 10:23 AM
Quote - Thanks so much nightfall.
cheerio
lululee
Yes you just need to double-click and install.
It will take quite sometime though and you will need to reboot at the end.
lululee ( ) posted Wed, 22 April 2009 at 10:30 AM
I am off to do the deed.
wish me luck.
cheerio
lululee
lululee ( ) posted Wed, 22 April 2009 at 11:17 AM
VICTORY!
Thanks so much for your time and patience, nightfall.
All is well and Quicktime works after the upgrade.
You made my week.
cheerio
lululee
