Try Apple's site - if they don't have it on the main page for XP, try a search on their site, they usually have legacy versions available.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
For an older OS
Navigate to the apple.com page (in my post above) to download quicktime using your 64-bit Internet Explorer.
Only then will you be able to download the 64-bit quicktime (it's still a 32-bit program, but it plays nice with 64-bit OS). Hopefully this helps.
So what error do you get when you try to install (if any) or play the video? And what player are you trying to use ? Did you try that media player classic thing that alt. quicktime installs ?
Also note that you can't use any 64 bit player or tool to work with quicktime as it is 32 bits. Only 32 bit ones will work, even if you run them under XP 64.
Quote - nightfall,
Here is what i get when I right click on the properties.
i really appreciate all of your help.
cheerio
lululee
The screenshot says Service Pack 1.
You can get get XP64 SP2 from MS
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=893FD6C0-6283-44C3-BB84-B2F0315B2AE6&displaylang=en
](http://www.microsoft.com/downloads/details.aspx?FamilyId=893FD6C0-6283-44C3-BB84-B2F0315B2AE6&displaylang=en)Newer versions of quicktime requires XP SP2 and above.
Quicktime 7.3 is the last version that supports XP SP1 iirc.
Quote - Thanks so much nightfall.
I have very little system skills.
Once I have downloaded the update, is it ok to just click and install it?
I wonder why it did not get that update on it's own.
Again, I really appreciate your help.
cheerio
lululee
Yes you just need to double-click and install.
It will take quite sometime though and you will need to reboot at the end.
Hi
Does anyone know if there is any kind of update that makes it Is it possible to play Quicktime videos in Windows XP pro 64 bit?
cheerio
lululee
