Thank you all for your comments, the cr2 file is definately pointing at the right object file I did replace the original object file with the new object, but only after I deleted the corresponding rsr file and the object loads into uv mapper displaying the map that I put together so I guess I did replace it. Still confused but feeling better for having checked those things again......any other thoughts? this is driving me crazy!!
Right - you said it loads from the geometries file and maps fine, I should have figured Poser 4 from that... When you load the object from the library, try exporting it and loading it back into UVMapper to see how it's texture mapped. That might give you a little more infoirmation... Sorry, it's all I can think of. Good luck, Steve
I've re-mapped a figure object in uv mapper, saved it, and it seems to be loading fine, but the texture map that should correspond with the new object doesn't, I have loaded the new object straight from the geometries file and it maps fine, but when I bring it in from the library it doesn't !?! I'm confused....any thoughts?
