Vue F.A.Q (Last Updated: 2024 Sep 17 9:46 am)
Will,
Can you post a small pic of the bumps in maya versus those in Vue. Perhaps if we see it, we can suggest some other improvements. Here are some other things to check:
Render settings: are you using texture filtering, what are your texture AA setttings
Did you try inverting the bump depth - for example, if the depth is set to 0.5 try setting it to -0.5 and see if this makes a difference
I assume you are using Object Standard mapping for the bump map material - yes?
I've had to crank AA up high for bump image maps. Maybe there is a setting for Vue to leave images as they were imported and not mess them up by default?
My stuff is for Poser, and as you've found the solution to your actual problem, but my Poser Optimization tutorial does hold a few points that apply in general for importing figures, .pz3 or obj, that maybe of use toyou, link is in my signature :)
Another thing though is when bump maps images are too small in size you get .jpg artifacts showing, damn I hate that, which is why I always keep copies of originals of textures, so I can use big originals for bump/displacements if necessary.
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
I've found that TGA files get left alone by Vue more than JPG. For some reason, Vue wants to compress JPG files even further during import. And BMP's are too big RAM-wise to be using.
I've been playing with Infinite Vue 7.51's bumps and found a way that works once again:
The secret is to use a low value of 0.1 for small objects around a foot or two in size. A value of 1 is for use on larger objects that could be 50ft or more in size. Bilinear interpolation should be used on bump texture maps. A "-" sign will invert the bumps.
The "-" sign was broken in some instances before.
Hi guys,
I've hit a small snag. I've imported my dinosaurs into my scene as .OBJs without many problems. However, when I render even on highest quality the bumps dont look very good, almost pixilated in appearance. They look fine in Maya so I'm not sure whats happening. How can I fix this? Thanks,
Will.
