Sat, Jan 25, 4:11 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 24 5:53 pm)
Subject: Painful Medical Condition for M4
Klebnor ( ) posted Thu, 07 May 2009 at 10:51 AM · edited Sat, 25 January 2025 at 3:50 AM
I don't know if I did something wrong, or if this was the intent but perhaps someone can straighten me out.  If you attach the M4 gens, and dial up M4 to have a beer belly (or even just bulk or heavy) the gens stays where it started, and is inundated or subsumed into the corpus.  That's got to hurt.  Has anyone else noticed this condition, or did I do something wrong in not getting those morphs into the Gens object?
Klebnor von Weisenacre
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device.  Beige horizontal case.  I don't display my unit.
JenX ( ) posted Thu, 07 May 2009 at 10:57 AM
Probably going to regret asking this
Did you add the morphs to the gens, too?  Or are they in there to begin with?  (Shows how often I use M4)  And, yeah, that's GOTTA hurt.
Klebnor ( ) posted Thu, 07 May 2009 at 11:02 AM
Can you add morphs to the gens?  It seems to have some, but not all, in it's "native" state (ie as it is created by the installer and updater).
How would one add morphs to the gens?  I thought the morphs were specific to the object (M4).  I don't have a folder for gens morphs (that I can find - is there one created during install?).
I do not use power loader, as I use Carrara.  Would that be required to load them?
Thanks.
Klebnor Von du Lac
Dialer ( ) posted Thu, 07 May 2009 at 11:22 AM
The morphs for the gens are part of the Morphs++ package. You don't have to use the Power Loader, as that's just a convenience. If you need to search for it on your HD, the actual installer file name is 7878_2_dpc_M4Genitalia.exe.
HTH
Klebnor ( ) posted Thu, 07 May 2009 at 11:37 AM
Dialer:
Thanks.  Actually, I think you have to install that file to have M4 Gens at all.  I did that.  It's just that the installed morphs do not include a number of the corresponding body morphs.  I was looking for some way to find and load the additional morphs, or maybe only slender M4's are allowed to have gens.
Regards.
Dialer ( ) posted Thu, 07 May 2009 at 11:48 AM
Ah, you're right. Have you loaded Morphs++?
Klebnor ( ) posted Thu, 07 May 2009 at 12:33 PM
Dialer:
Yes, I have Morphs++, and have successfully loaded them into M4.  I have even tried injecting them into the M4 Gen, although this doesn't seem to do anything.  Since they are trying to morph much more than just the small piece of common geometry, I don't think these morphs (intended for M4) will work on the gens.  There are clearly some morphs included with the gens (bodybuilder, superman, thin, etc) but not the heavy, bulk etc.  Thus, if you dial up the  torso at the hips, the attachment mesh stays put and, from an external view, sinks inside the body.
Painful (and not very realistic).
Dialer ( ) posted Thu, 07 May 2009 at 12:47 PM
Ouch.
Sorry, but I'm not experienced enough to offer any other suggestions. Good luck!
RHaseltine ( ) posted Thu, 07 May 2009 at 2:50 PM
I'm pretty sure the genitals don't have the BeerBelly morph - not sure about the others.
Klebnor ( ) posted Thu, 07 May 2009 at 3:24 PM
But they should!
Imagine the hydraulic pressure!
JenX ( ) posted Thu, 07 May 2009 at 3:55 PM
Quote - But they should!
Ok, I should know better than to read anything about toast with liquid in my mouth by now, LOL
DarwinsMishap ( ) posted Wed, 27 May 2009 at 11:30 AM
My question-Do you have his gen under his hips in the hierarchy?  Perhaps you are having that 'sinking' feeling Snicker due to the gens remaining stationary while they body is being morphed/moved?
I haven't tried to morph the gen in Carrara yet-I'll try tonight and see if I can figure this out.
Besides----it'd be too amusing to see to pass up. :)
Klebnor ( ) posted Mon, 01 June 2009 at 1:25 PM
Gen is conformed to M4, it does not seem parented to any particular part (when viewing the hierarchy).  I would say, however, given the physical appearance, that it is parented to the hips.  Where else?
I believe that the problem is simply that many morphs which expand the torso were left out of the M4 Gens when it was created, and I simply lack the programming skills to insert them.
Klebnor
