Thu, Jan 30, 1:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 12:25 pm)
Subject: Parenting
Merlin_Studios ( ) posted Sun, 10 May 2009 at 12:47 PM · edited Thu, 30 January 2025 at 12:58 PM
Hello, I've modeled a sword and scabbard in OBJ format and imported it into Poser 7 no problem.  I've positioned the models and parented the sword to the scabbard and the scabbard to the hip of M4 and it all works fine and as expected.  I then save as a prop into the library.  When I delete the prop and reload it from the library, it's no longer parented to the hip of M4.  Is there any way of saving the parent information to the hip?
Thanks, hope this makes sense!.
Merlin.
jt411 ( ) posted Sun, 10 May 2009 at 12:53 PM
When you add the prop to your props library, Poser should give you a pop-up saying something like: This prop has a parent, save as smart prop?
If you're saving the sword and the scabbard together, click "Select Sub set" from the save window.
ockham ( ) posted Sun, 10 May 2009 at 1:03 PM
Poser won't let you save two things as a smart prop.   When you click "Select subset"
so you can check both the sword and scabbard, you can't use the smart-prop
choice.
Easiest solution is:
1.  Save the sword and scabbard (parented together, and
correctly positioned on Mike) with the "Select subset" choice.
2.  Then edit the PP2 file to make the scabbard into a smart prop.
In the PP2, find the line
parent UNIVERSE
and change it to
smartparent hip
This will make the scabbard a smartprop, and the sword will still be parented
to the scabbard.
My python page
My ShareCG freebies
Merlin_Studios ( ) posted Sun, 10 May 2009 at 1:09 PM
Excellent, thanks very much for your help, I shall give that a go.
