*BTW is there any way to change an image in the gallery. I have updated my last one and tried editing it, but it didn't seem to want to play.
*Members cannot replace an image once it's in the gallery and I don't think I have the authority to do it for you, but I'll check.
It's OK, I renamed the revamped version, so it was the same as the first one, called that by another name, reloaded it and it did update. It's not a great image, but it will serve for what it was designed for.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
I think it is the lighting that is making it look flat. IMHO. The image lacks the shadows of 3d piece. Maybe the post work covered the shadowing. The light is coming from the left and I see shadows on her sleeve and mountains in background but the post worked water and ground cover has perhaps covered it all up.
I asked the powers that be about this and got a reply.*
Q: BTW is there any way to change an image in the gallery. I have updated my last one and tried editing it, but it didn't seem to want to play.
A: Yes I do it all the time. Member needs to clear cache and refresh screen
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1882611
Rather than post another WIP I put the new version in the gallery,Thanks for the help
Quote - I think it is the lighting that is making it look flat. IMHO. The image lacks the shadows of 3d piece. Maybe the post work covered the shadowing. The light is coming from the left and I see shadows on her sleeve and mountains in background but the post worked water and ground cover has perhaps covered it all up.
I was going to say the some thing..I totally agree with you.
Nice picture btw. Good composition.
Thanks Alan. Yes i was going more for an illustrative look, but di want a degree of realism.
Have decided that partt of my problem is getting Poser skin textures to look good in Bryce. I had a good format going for the older figures and textures, but nowadays all the skin tex are slanted towards use in poser only, with loads of nodes attached, and look c**p when transferred. I am having the same problem with my latest effort as well.
OK I have postworked the water, but otherwise it is straight out of Bryce. It's not right.
Any suggestions, welcome. Go on pull it to bits please.
