Sat, Feb 15, 12:10 AM CST
Forum Moderators: Staff
Subject: Pose able prop vs Pose able figure
nyguy ( ) posted Fri, 22 May 2009 at 9:23 AM · edited Sat, 15 February 2025 at 12:08 AM
I am working on an interior scene. I have several parts to this, doors that opens and other movable parts. Now I am wonder if it is better to save it as a prop or as a figure or does it matter? I have it already saved as a figure.
Poserverse The New Home for NYGUY's Freebies
EnglishBob ( ) posted Fri, 22 May 2009 at 9:49 AM
If there's rotation involved, you need it to be either a posable figure, or a series of parented props with their centre points adjusted accordingly so the hinges appear in the right place.
Sliding doors etc. which involve only linear motion can be done as a morphing prop.
nyguy ( ) posted Fri, 22 May 2009 at 1:27 PM
Quote - If there's rotation involved, you need it to be either a posable figure, or a series of parented props with their centre points adjusted accordingly so the hinges appear in the right place.
Actually this prop has a sliding door, and an elevator.
svdl ( ) posted Fri, 22 May 2009 at 2:40 PM
I'd suggest a posable figure (with bends off on the joints). Even though a morphing prop is possible, the posable figure is more versatile - for example, you could hide/show the elevator or door body parts as needed.
It might even be useful to designate the four walls and the ceiling as separate body parts - removable (hidable) walls are a great benefit for interior scenes.
That actually mirrors interior sets used in the television/film industry - retractable/removable wals for easy camera access.
My gallery   My freestuff
JoEtzold ( ) posted Sat, 23 May 2009 at 2:41 PM
Also a posable figure can be deleted with one action where otherwise you have to delete all props each by each in case you will unload the scenery.
ockham ( ) posted Sun, 24 May 2009 at 5:14 PM
One more item in favor of a figure: you can apply pose files for motion and
materials directly to it.   If you rig it as a prop, then the user will need to
have a figure somewhere in the scene before any pose files will work.
My python page
My ShareCG freebies
nomuse ( ) posted Mon, 15 June 2009 at 6:48 PM
Hacking the cr2 is useful here; you can set the scale dials to "hide," and make selected translate dials visible.  With the dial re-named and limits set the end result can be quite elegant.
MistyLaraCarrara ( ) posted Wed, 17 June 2009 at 9:44 AM
Quote - I'd suggest a posable figure (with bends off on the joints). Even though a morphing prop is possible, the posable figure is more versatile - for example, you could hide/show the elevator or door body parts as needed.
Hi svdl, i was checking out your cool freebies.  Does the spawn character script work on TY2?
(I had to make a morph to flatten her glutes for a mermaid tail I made for her.)
thanks.  cheers - Lara
svdl ( ) posted Wed, 17 June 2009 at 2:18 PM
Quote - Does the spawn character script work on TY2
Sorry, it doesn't. It's geared towards figures that have PBM_CC and PBM_DC injection channels, and TY2 doesn't have those, AFAIK.
When I have the time, I'll make a version that'll work on figures without injection channels too.
MistyLaraCarrara ( ) posted Wed, 17 June 2009 at 2:27 PM
I was wondering what all those PBMCC were for, H3 has them all over the place.
After I save my H3 or A3 character to a full body morph,
can I delete those PBMCCs without breaking the character?  Will it speed them up?
Thanks.
