Mon, Dec 23, 4:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: Need help with render settings...PLEASE!! ;o)
LaurieA ( ) posted Wed, 27 May 2009 at 8:37 PM · edited Mon, 23 December 2024 at 12:21 AM
Forgive me for the STOOPID question: I've been away from Poser for a long time, have only been fiddling with Poser 7 for about a week and I'm forgetfull! LOL. Anyway, I'm sure it's something simple...
I render in the default settings and Aiko looks like the above. I've included the render settings...
LaurieA ( ) posted Wed, 27 May 2009 at 8:39 PM
Now, I turn on Raytracing and poor Aiko looks as though she's been rolling around in a dirt pile. I've include the render settings for this also (it doesn't seem to matter if Cast Shadows is checked or not).
What am I doing wrong? Is it a graphics card or driver thing? Or is it a simple setting (hold breath)?...
Thanks in advance,
Sa_raneth ( ) posted Wed, 27 May 2009 at 8:46 PM
try shading rate at .20 raytracing at 6 cast shadows  raytracing on  smoth polys  and displacement map irridance chaching  should be  round 80 or 90
i make no garuntees  but   it  works for  me that  way
replicand ( ) posted Wed, 27 May 2009 at 8:59 PM
 Looks like really splotchy AO
hborre ( ) posted Wed, 27 May 2009 at 9:03 PM
I'm inclined to agree with replicand.  Is there AO set on any of your lighting?
LukeA ( ) posted Wed, 27 May 2009 at 9:18 PM
Attached Link: link
Also look here :)
http://www.keindesign.de/stefan/poser/renderer.html
LukeA
My latest novel
LaurieA ( ) posted Wed, 27 May 2009 at 9:52 PM
I DO have AO in the scene. I have to admit I don't know much about it, except that it makes the lighting look better somehow.
Is there something I have to change in the AO settings?
LukeA: thanks for the link. Gives me a bit more understanding of the settings and what they do :o).
Thanks everyone for the help thus far.
hborre ( ) posted Wed, 27 May 2009 at 10:56 PM
Try the following settings and note any improvement:
Irradiance caching: 95 - 100
Pixel samples: 5 - 7
Min. shading rate: 0.2
Enable Smooth polygons and Use displacement maps.
LukeA ( ) posted Wed, 27 May 2009 at 11:09 PM
You only need to enable use displacement maps if you are using them in the scene, otherwise it is a waste.
LukeA
My latest novel
markschum ( ) posted Thu, 28 May 2009 at 1:10 AM
It looks like you are getting shadowing on all the cloth bumps , but odd patterns on the skin  ?
turn ao off and see what happens
LaurieA ( ) posted Thu, 28 May 2009 at 1:48 AM
Well, according to that link that LukeA gave, you don't really NEED raytracing unless you've got a lot of reflections and refractions in your scene. I'd still like to get it to work tho.
Thanks everybody :o).
IsaoShi ( ) posted Thu, 28 May 2009 at 7:57 AM · edited Thu, 28 May 2009 at 8:00 AM
AO requires raytracing switched on, but it does not require any bounces.
It looks to me like your AO bias setting is too low. On a bumpy skin, this will produce self-shadowing.
Suggest change your scene AO settings to:
Samples: 8
Max distance: leave it as it is.
Bias: try 0.1 inches (the "inches" is important. If you don't use inches in Poser, you need to convert this value).
(edit) the "scene AO" options are on the light properties, in case you didn't know.
