Tue, Feb 11, 1:19 PM CST
Subject: M4 Bodysuit problems.
meltz ( ) posted Mon, 01 June 2009 at 1:26 PM · edited Tue, 11 February 2025 at 1:01 PM
I just bought this from daz, expensive buy. But i cant seem to get ride of these nasty lines/seems. Now they have a no seems in the library but this is what the no seems looks like =( anyone else have this item that maybe knows something that i am over looking?
also any idea how i get rid of that bumpy texture. i beleave there is no bump map loded into this
hborre ( ) posted Mon, 01 June 2009 at 2:41 PM
It looks like either a bump map or displacement map is active.  If you post your Material Room settings we might get some idea what's going on.  I have used the no seam feature on the bodysuit and have experienced no problems.  Check out the gallery link:
http://www.renderosity.com/mod/gallery/index.php?image_id=1808005
meltz ( ) posted Mon, 01 June 2009 at 3:06 PM
dude all you did was click on the no seems library? cause when i do that it still leaves those lines.
PS what screen shot would help? advanced materail room ?
hborre ( ) posted Mon, 01 June 2009 at 3:36 PM
Advanced Material room.
meltz ( ) posted Mon, 01 June 2009 at 4:09 PM
ok so the whit texture i was using was all screwed. so i started over this time with the defaulyt black texture. I clicked on no seems, then went into material room and saw there was a bumpmap still loaded. so i took all the bumpmaps out and now this is what is left. Still getting seems and now there are streeks in the texture. I have no clue what is wrong but all i know is for the $$$ this item was it should be one click and fixed ya know.
chriscox ( ) posted Mon, 01 June 2009 at 4:17 PM
Try using the seams gone morph
Chris Cox
meltz ( ) posted Mon, 01 June 2009 at 5:56 PM
seems gone morph didn't change anything. Daz got back to me and said to turn off texture filtering in the material room. Anyone know how to do this?
hborre ( ) posted Mon, 01 June 2009 at 6:09 PM
Look on the color_texture node towards the bottom of the text.  You will be looking for 'Filtering' and right next to that will be a pull down menu.  Change that to none.  What Poser unit are you using in the General Preferences?  Inches?  Feet?  CM?
meltz ( ) posted Mon, 01 June 2009 at 6:15 PM
i am using FEET
hborre ( ) posted Mon, 01 June 2009 at 6:29 PM
If the gradient_bump uses the same conventions as the bump value on the Poser surface, the value you posted is way too high.  If I'm correct, your bump value is 1.5 feet!  Perhaps someone else may elaborate further on this specific feature.  Meantime, disconnect your bump_map and re-render your image.
meltz ( ) posted Mon, 01 June 2009 at 7:12 PM
cool the disconnect bump map worked along with smooth seems morph. Looks like this will be just fine from here on out. Thanks guys once again.
hborre ( ) posted Mon, 01 June 2009 at 7:17 PM
Excellent, you figured it out.  I was about to post several images to illustrate but you managed.  The bump_map in the material room also defined the seams on the suit.  By disconnecting it from the Poser surface, you eliminated all traces.
meltz ( ) posted Mon, 01 June 2009 at 7:18 PM
Yeah thanks so much man you are always a huge help. Im such a noobie lol
