Sat, Nov 30, 8:31 PM CST
Subject: Which shadow is better? Ray Trace or Depth?
richardson ( ) posted Sat, 16 May 2009 at 1:44 PM
Light is 0angle start 70end
richardson ( ) posted Sat, 16 May 2009 at 1:45 PM
Light is 160start 12end. No change. This is Shadowmapped but it's the same with RayTrace.
richardson ( ) posted Sat, 16 May 2009 at 1:57 PM · edited Sat, 16 May 2009 at 2:02 PM
As to my thoughtless idea on having multiple mainlights,,, that creates a new set of rogue shadows that need to be tuned down and out of the non shadowed area (In this box test). Bias has to lower too.  Big pita in a dark scene but good I think for studio lights.
Increasing the light distance helps obviously but with SM spots means raising the map size to avoid breakup and costs in rendertime.
carodan ( ) posted Wed, 03 June 2009 at 4:54 AM
Can someone please direct me to information about the Inverse Square Falloff node setup for lights? I did a forum search but I'm not convinced I found the best setup.
PoserPro2014(Sr4), Win7 x64, display units set to inches.
                                      www.danielroseartnew.weebly.com
ice-boy ( ) posted Wed, 03 June 2009 at 5:53 AM · edited Wed, 03 June 2009 at 5:54 AM
one second
ice-boy ( ) posted Wed, 03 June 2009 at 5:55 AM
carodan ( ) posted Wed, 03 June 2009 at 6:06 AM
Thanks ice-boy.
So I just have to remember to input the correct reference and light position into the nodes - Poser needs a built in version of this for sure so we don't have to enter these extra values (gets tricky with lots of lights as I'm using a fake area-light array).
bagginsbill ( ) posted Wed, 03 June 2009 at 6:39 AM
Biting my tongue. Biting my tongue. Biting my tongue.
carodan ( ) posted Wed, 03 June 2009 at 6:50 AM
Sooooo.........I think I may hold off adding lots of nodes to all my lights (maybe just play a little). Ahem
I'd be surprised if you have a tongue left by the time P8 actually gets released.
ice-boy ( ) posted Wed, 03 June 2009 at 1:03 PM
i am still searching for some papers for fast soft raytraced shadows. i found two.
could this be in the future in poser?  bagginsbill you are the expert. what do you think? could this work with firefly?
artis.inrialpes.fr/Publications/2005/LAALA05/SoftShadowVolumesRT.pdf
www.tabellion.org/et/paper07/egsr07_mtsm.pdf
faster shadows are always good right he he :)
bagginsbill ( ) posted Wed, 03 June 2009 at 7:48 PM · edited Wed, 03 June 2009 at 7:49 PM
If we abandon displacement, yes these could be made to work. (Notice that Kerkythea, last I looked, did not support displacement but does support some very advanced lighting models.)
I'm actually not an expert on Firefly - stewer is. You should ask him. I know about some of its limitations, but I've never seen the code. I know, for example, that reflections don't track displaced surfaces correctly, but displacement was there first. Obviously adding ray-tracing to a REYES renderer is a compromise.
But there is no reason they should stick with Firefly. I really don't care too much what the renderer is and would be happy to use several dozen. What I don't want to deal with is several dozen different models for materials.
ice-boy ( ) posted Thu, 04 June 2009 at 3:31 AM
aha i understand.
i am still suprised that after 10 years there are no mroe information on shadows that are fast as DM shadows and realistic as raytraced.
i guess it is hard to combine them together.
ice-boy ( ) posted Thu, 11 March 2010 at 3:29 PM · edited Thu, 11 March 2010 at 3:32 PM
i remember that this was answered in another thread but i can not find it. i get problems with those lines on the ground.
my shadows settings are:   raytraced,blur 20 and bias 0.8 .
ice-boy ( ) posted Thu, 11 March 2010 at 3:30 PM
hborre ( ) posted Thu, 11 March 2010 at 3:33 PM
IIRC, increase your bias.
bagginsbill ( ) posted Thu, 11 March 2010 at 3:43 PM
Sometimes smoothing forces you to use a larger bias than you want. Do you have smoothing on? If so, disable it on the prop, so you can keep smoothing other things, and see what happens.
ice-boy ( ) posted Thu, 11 March 2010 at 4:07 PM
if i disable smoothing on ground its the same.
i modeled this myself and its not textured yet so i can change the model. should i model it in a special way?
bagginsbill ( ) posted Thu, 11 March 2010 at 4:33 PM
I don't know. I'm not much of a modeler. So far, what models I've made, I've not seen what you've got there.
Upon looking more closely, I see that all of the polygons are outlined, even the ones far away.
Are they welded? They should be. Are they double sided? They should not be.
ice-boy ( ) posted Thu, 11 March 2010 at 4:53 PM
i imported in blender now and made it not double sided and also used welded .
its the same.
thanks for the help. but i guess its just a bug or something.
