Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 12:32 pm)
That's pretty freakin' awesome :) Thanks for sharing!
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Very nicely done. I'll have to add that technique to my materials library. Thanks for sharing.
Posermocap - Motion Capture animations for Poser and Daz3D.
Note that the Tile node "Tile" that is connected to Transparency and Bump is strictly there to obtain a clothlike appearance and has nothing to do with the camouflage color.
By the way if anybody's curious about the model shown:
http://www.renderosity.com/mod/gallery/index.php?image_id=1900861
swimsuit for SP3, for which I decided to fiddle around with some new materials, enjoy :)
Quote - Note that the Tile node "Tile" that is connected to Transparency and Bump is strictly there to obtain a clothlike appearance and has nothing to do with the camouflage color.
this a gem. Thanks. clothlike appearance is a big help to learn.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
It took a long while for me to get it looking reasonable actually, for a long time I had bump strength turned up much too high. That number listed for bump strength is a distance value and won't be the same for you if you're not using the same Poser measurement unit (mine is set to Feet). If you notice a "checkerboard" pattern in renders that seems to follow the model's wireframe geometry, it is probably because the bump strength is set too high.
My Freebies
