Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Geep, isn't that the tear off for a separate rendered image window? Didn't think it would automatically save to file.Â
michael_REMY: the purpose of the export image is to select what format you would like to save your render as. There are better formats than just jpeg which is a lossy format, it doesn't retain pixel information readily when scaling and resizing. BTW, there is nothing gentle about this forum, we're a rough and tumble group. He he.
@ **hborre
Yes ... and No, it does not "automatically" save but it's relatively easy to use since it's only one click and it's right there, i.e., you don't need to use the menu(s) ... .
It was just a suggestion ... then later on, you can save** (or not [X]) **the ones you want to keep.
I use this frequently to do a bunch of test renders because it's fast and convenient.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: Firefly render scipt
Or you could download D3D's free script that provides a lot of control over the render process, including auto saving to your preferred destination.Windows 10 x64 Pro - Intel Xeon E5450 @ 3.00GHz (x2)
PoserPro 11 - Units: Metres
Adobe CC 2017
Quote - @ **hborre
cheers,
dr geep
You can save any of them? On my P7, it only lets me save the last one I rendered. Is there somewhere I can set this to enable me to pick which one(s) I want to save?
Quote - So, unless animating, one must still save each of them one at a time.Â
No one has yet discovered a method to batch convert all the files in the Poser Render Cache from their raw (.tmp) format to some common image format?
Da NaySayGuy is werkin' on it ........... but don't hold yer breath. :scared:
:lol:
cheers,
dr geep ... :o]
edited 10/5/2019
hi !
During my design process, my i make many renders, just picture.
I would like to save them without having to open the Menu, then selecting 'export image'...
i think this way is very boring...
is there any other method to save the render ?
Thanks for reply and help me ! it is my first one in this gentle forum !
