Yes, you have to load the obj you want into UVMapper, make the mapping the way you want it and resave the obj. Of course if you resave over the original, the new prop will have your mapping. If you want separate material zones, you'll have to set them up as such, which I think can only be done in the pro version. I haven't checked tho, so I may be wrong. It's been a long time since I've used the free verson :o).
Quote - hmm, still same problem... I noticed the model came with its own textures, but those don't seem to work either
Then you saved over the original model. Your best bet (if you want to use both mappings) is to save the obj file you made the map for with a different name and import THAT into your program.
What I'm finding so far (and I'm not done with it yet), is that most of this car has no textures. The material zones are there, but only some have an actual texture map.
As for UV Mapper, I can see the groups (which correspond to the materials), but I cannot assign them to a material because there are no uvs. I'm going to continue with it further - it's tricky because it's in French, so I have to translate the different parts...LOL.
I'm gonna keep at it for awhile :o)
Quote - yeah, that's the problem I had, I could create a new UV file, bur for whatever reason I couldn't attach any actual textures to it. Even loading the original file in Poser and selecting the textures by hand, they only show up black
You're better off using Poser's shaders for most of the parts anyway. I'm still working on the other parts :o).
I posted a few screen-shots of mapping a basic model in Wings3d.
In case it's helpful-
near the bottom of this thread:
www.renderosity.com/mod/forumpro/showthread.php
(www.renderosity.com/mod/forumpro/showthread.php?thread_id=2773536)
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
I recently grabbed a freebie car and wanted to do some custom texture work on it, but found that it has no UV map of any kind, is there a way to add one? I tried to use UV mapper, but while it can give me a map, I can't apply it to the car
