Tue, Dec 24, 12:27 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 19 7:58 pm)
Subject: Daz Studio 3 Pro all my installed content vanished! Help!
Pedrith ( ) posted Fri, 10 July 2009 at 5:55 PM · edited Tue, 24 December 2024 at 12:27 PM
 Hi.  I'm new to Daz Studio 3 Pro.  I did something (god knows what) and all my installed content (V4. A4, H4, M4) among others items vanished.   The content is still on the computer, but program can't seem to see it.  Do I need to reinstall all my content, or is there some way to force the program to search for DS Content?  I tried adding it as an additional directory but nothing happened.
All help is appreciated.
David
mishamcm ( ) posted Fri, 10 July 2009 at 6:57 PM
On the Content tab, click on the little triangle in the upper right corner and switch to one of the Folder views.  If your content shows up under Folder view, then it should show up in Category view after a Search for Content.  If it doesn't, you need to go into Edit >Preferences>Directories and look at what's listed for "D|S-format content folders" and "Poser-format content folders."
Katanas ( ) posted Fri, 10 July 2009 at 10:06 PM
Did you change your Preferences Directory pointer. Go to the 'Edit' tab, select 'Preferences' then click on the 'Directories' tab in the window. Listed are the directories your program is looking at, if there is none there, click on 'Add' and add each 'Contents' to the list.
Otherwise do a 'Search for Content'...
-Timberwolf- ( ) posted Sun, 12 July 2009 at 9:57 AM · edited Sun, 12 July 2009 at 9:58 AM
To be honest ,I am used to Poser's runtime management.DAZ-Studio's folder system still apears very cryptic to me.Not only that I don't get it,I think  it doesn't make much sense.I expect to see the same folder hirachie in the app, as I see in my windows explorer but this has changed with release 2.xxx .
mishamcm ( ) posted Sun, 12 July 2009 at 10:07 AM
Quote - To be honest ,I am used to Poser's runtime management.DAZ-Studio's folder system still apears very cryptic to me.Not only that I don't get it,I think  it doesn't make much sense.I expect to see the same folder hirachie in the app, as I see in my windows explorer but this has changed with release 2.xxx .
Click on the little triangle in the upper right corner of the Content tab and choose one of the Folder views to get the old view.
Pedrith ( ) posted Wed, 15 July 2009 at 8:10 PM
 Thank you very much for all the responses.  I did a search for content and found everything and then some.
Sincerely,
David
