Sat, Feb 1, 2:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 12:52 pm)
Subject: where can i get talk designer for toon boy sam??
AnyMatter ( ) posted Tue, 14 July 2009 at 10:39 AM · edited Sat, 01 February 2025 at 2:49 PM
hi!!!
i need some help??
where can i get a talk designer of xml format for toon boy sam??? does anyone knows??
ermm, i have mimic pro, but when i import SAM , his morph does'nt seems to work.
for an example, when i select the open lips, and adjust the strength, and clicked the preview at phoneme list, his lip doesnt open, even with maximum strength? any idea??? o maybe mimic pro doesnt support toon boy sam figure yet??
hope there's a reply, thanks
SAMS3D ( ) posted Tue, 14 July 2009 at 10:58 AM
 Have you updated Talk Designer?  A update came out a little while ago and I had the same issue, then I made sure all my updates were in place for Poser 7 and shut down after the updates and all worked.  Sharen
kirwyn ( ) posted Tue, 14 July 2009 at 11:00 AM
I don't have Sam, but according to the Daz site, a custom Mimic .DMC file is included in the purchase.  The use of this file should enable Sam to talk in Mimic.
AnyMatter ( ) posted Tue, 14 July 2009 at 6:05 PM
Quote -  Have you updated Talk Designer?  A update came out a little while ago and I had the same issue, then I made sure all my updates were in place for Poser 7 and shut down after the updates and all worked.  Sharen
hi!!!
thanks for the reply!!! btw, how do i update talk designer??? is it just dowload the latest .zip file at
http://my.smithmicro.com/win/poser/updates.html??? do sam had xml file for lipsync in talk designer, instead of mimic pro??? where can i get his xml file..... :-) . thx
SAMS3D ( ) posted Wed, 15 July 2009 at 6:17 AM
 You have to contact the makers of Talk Designer, the respond quickly, but usually, your updated Talk Designer should already be in your account.  Just re-download and install.  If you have questions, email the originators of Talk Designer and ask them about the update, like I said they will have an answer for you right away.  Sharen
