Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 10:44 am)
Quote - Have you updated Talk Designer? A update came out a little while ago and I had the same issue, then I made sure all my updates were in place for Poser 7 and shut down after the updates and all worked. Sharen
hi!!!
thanks for the reply!!! btw, how do i update talk designer??? is it just dowload the latest .zip file at
http://my.smithmicro.com/win/poser/updates.html??? do sam had xml file for lipsync in talk designer, instead of mimic pro??? where can i get his xml file..... :-) . thx
You have to contact the makers of Talk Designer, the respond quickly, but usually, your updated Talk Designer should already be in your account. Just re-download and install. If you have questions, email the originators of Talk Designer and ask them about the update, like I said they will have an answer for you right away. Sharen
hi!!!
i need some help??
where can i get a talk designer of xml format for toon boy sam??? does anyone knows??
ermm, i have mimic pro, but when i import SAM , his morph does'nt seems to work.
for an example, when i select the open lips, and adjust the strength, and clicked the preview at phoneme list, his lip doesnt open, even with maximum strength? any idea??? o maybe mimic pro doesnt support toon boy sam figure yet??
hope there's a reply, thanks
