Fri, Jan 10, 9:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 9:07 am)
Subject: Painter 3D SE
cheshire ( ) posted Thu, 30 September 1999 at 5:59 AM ยท edited Fri, 10 January 2025 at 8:51 AM
Is there a fix out there for the XXX that appears on the Import menu? I know it's a missing or corrupt resource file that's causing the problem, but don't know if a fix has ever been found. Thanks. Jim
bloodsong ( ) posted Thu, 30 September 1999 at 8:12 AM
heya; yes, there was a fix posted on the metacreations site. (click on link at right.) i've never gotten it yet, since i figured out which xxx means 'obj.' :)
cheshire ( ) posted Thu, 30 September 1999 at 8:15 AM
Thanks. However, the link on the Metacreations site appears not to be for Painter 3D SE. When I tried to install it, it told me Painter3D was not properly installed. I continued anyway (always a bad idea, by the way) and then it wouldn't let me start Painter3D because it wanted a serial number. I had to remove Painter3D and reinstall it. Oh well. Jim
Foxhollow ( ) posted Thu, 30 September 1999 at 3:51 PM
I did try Painter 3D for a short time and got the patch required for Poser from Meta. It may have beem listed under Poser rather than Painter. It WAS noited as a patch for Painter 3D and Poser. The file name was pd3_101_patch.zip and was about 2.5 mb.
cheshire ( ) posted Thu, 30 September 1999 at 4:10 PM
That certainly sounds like the exact file I downloaded. Maybe I'll explore some more what's going on here. Thanks.
bloodsong ( ) posted Thu, 30 September 1999 at 7:01 PM
heya; i think 'obj' is the last xxx on the list. you can try just using that. i mean, if youre desperate! :)
hebdemnobad ( ) posted Fri, 14 July 2000 at 9:40 AM
goto http://www.bryceworks.com/p3d/loadpzr/loadpzr.html the Painter 3d file that will fix this problem is there
