Sat, Dec 28, 8:38 AM CST
Subject: Nebulas, yet AGAIN! :p
silverblade33 ( ) posted Mon, 20 July 2009 at 9:07 PM · edited Sat, 28 December 2024 at 8:37 AM
reading Validimir and AMi's book..then Artur Rosa's section so started fiddlign with nebulas maybe it's Vue 7.5 or maybe I'm finally getting better :D
this is a sphere, actually
silverblade33 ( ) posted Mon, 20 July 2009 at 9:10 PM · edited Mon, 20 July 2009 at 9:10 PM
and original "terrain with volumetric nebula" but the material tweaked :)
sirenia ( ) posted Tue, 21 July 2009 at 6:33 AM
Hey wow, looking good man !!
Society failed to tolerate me...
... and i have failed to tolerate society
silverblade33 ( ) posted Tue, 21 July 2009 at 10:42 AM
Sirenia,
cheers! :)
quick gudie on thius but NOTE, it's very finicky and the settings for OVERALL DENSITY need tweaked to suit the scene
silverblade33 ( ) posted Tue, 21 July 2009 at 11:20 AM
opps heres the guide ;)
redtrek ( ) posted Wed, 22 July 2009 at 11:35 PM
I looked the settings over, and tried to figure it out for Vue 6.  Here's one with a terrain.  Still had to use distance field.
redtrek ( ) posted Wed, 22 July 2009 at 11:41 PM
And here's an attempt with a sphere.  I am assuming that one of the functions you used is a Vue7 feature, not available in 6.  I notice the edges do not fade out quite right in mine
silverblade33 ( ) posted Thu, 23 July 2009 at 6:45 AM
Redtrek,
hey they came out cool! :)
hm what feature isn't in V6? bit busy to load up and check at moment :p
(still have V6 on this rig as I've upgraded)
eonite ( ) posted Thu, 23 July 2009 at 12:09 PM
Thanks for sharing your know how on this , Silverblade!
Looks promising! Certainly a lot of potential with this volumetric nebula approach...
Still, I will probably stick to my 2D approach, since I am getting neat results while render times are kept within a reasonable range.
http://www.eonmusic.ch http://www.artmatica.ch
sirenia ( ) posted Thu, 23 July 2009 at 1:41 PM
Mine don 't come out so good. I seem to have this blue-ish glow all over the place.
sirenia ( ) posted Thu, 23 July 2009 at 1:55 PM
Oh... ignore my last post will ya.
I was doing it in the 'standard mode' and not in the 'volumetric mode' atmosphere model.
I just wanted you all to show AGAIN how stupid i can be sometimes LOL !!  ;-)
It is working great now :-)
silverblade33 ( ) posted Thu, 23 July 2009 at 2:25 PM
Eonite
my pleasure bud :)
oh, 2D, using a plane? intrigued
Sirenia
well, I'm just as silly as you then as I was using standard atmospheres ! ;)
never thought to use Volumetric atmosphere, lol! need to test that, you may hvae fiund a neat trick :)
I just hand tweak the nebulas, the density/fuzziness needs lot of work for each scene, usually.
Cherryman ( ) posted Thu, 23 July 2009 at 4:42 PM · edited Thu, 23 July 2009 at 4:47 PM
Hi all, i tried one too...
Not sure what you guys are looking for..
I tried it with a material combined from a volumatric with a hypertexture on a sphere
Additional info: Standard atmosphere.
Cherryman ( ) posted Thu, 23 July 2009 at 7:24 PM
Silverblade, did you try cloud layers also?
I did a quick test with bitmap driven cloudlayers, then you can create any shape, depth or multiple layers.
Here is a quicky inspired on the "Pillars of Creation"  Just a rough try.. but i think you can get good results when you start adjusting the quality, roughness, feathers etc..  just making advantage of the cloud settings at you're wishes.
Just draw it in a paint program and use that in the function editor to create any cloud in you're shape, turn of repeat so you get a single cloud,  Point the camera to the sky.
Original
sirenia ( ) posted Fri, 24 July 2009 at 9:49 AM
Cherryman your nebula 's look fantastic man ! This is as far as i can get it (see picture)
Oh and as far as that blue-ish thing from my first example, well... i think it 's some kind of bug in the preset atmosphere that come with Vue, the one with the stars in it. If i pre-load that atmosphere, it comes in all blue on it 's own !**
eonite ( ) posted Sat, 25 July 2009 at 6:46 AM
That looks cool and promising, Cherryman!
