Forum Moderators: RedPhantom
Something I have always had fun experimenting with is the Poser Puthon Script in GeoMods - Randomize Morphs
Semiedieu's Randomizer (HeadBody) works very nicely on both P8 Alyson and P8Ryan.
You can also INJ their Head Morphs into the Casual versions of Alyson and Ryan.
"That government is
best which governs the least, because its people discipline
themselves."
Thomas Jefferson
Thanks for the morph lists, mariner! That's a pretty impressive list there :)
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Dependent Parameters are a lot of fun to use as well.
You can use a Body Part or Prop Motion to control another Figure's Body Parts or a prop.
The motion on the other figureprop doesn't have to be the same as the control.
I just did a quick one in which I used Andy's Left Hand Up & Down to control Alyson's Head Twisting Left and Right.
I could have add more motions as well.
I could also use DP to control multiple segments of a tail etc.
For instance bending segment 1 (control) using DP could also bend Segments 2 through 10.
"That government is
themselves."
Thomas Jefferson
Quote - > Quote - Yep, looks odd plus this improved interface takes much more space up than the old one.
You can set it up however you like. For example, here's it arranged to be like the Poser 7 UI: tools, lights and camera on the background shell, document and paramters floating and the library docked to the right.
Ja, weiß ich doch alles :-) Ich benutze auch nicht das default PoserPro UI sondern ich hab es so angepaßt, wie es mir am besten gefällt. Hier beim P8 UI stören mich z.B. die Rahmen um die schwebenden Elemente. Das sind jetzt alles quadratische oder rechteckige Blöcke im Gegensatz zu den Elementen des alten Interface und wenn die zusammen gesteckt sind, bilden die einen großen Block - irgendwie sieht das nicht mehr so leicht und transparent aus wie im alten UI. Ich denke, das ist so der Hauptgrund, warum mir das einfach nicht richtig gefällt.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
Quote - > Quote - > Quote - Yep, looks odd plus this improved interface takes much more space up than the old one.
See, I'm the opposite. I got so sick of the "leicht und transparent" of the old interface that I can't wait to get my hands on the new one. I wouldn't mind if the extra rectangular border were only applied to docked elements and the floating ones left as they are in the current UI. But I'd probably end up docking everything anyway, so I don't really care much either way.
I just have one question...
With the new GI does it make everything look nice in PREVIEW?
My problem is custom morphing. Fake GI doesn't illuminate the preview enough, and classic lighting causes too many wrong preview shadings to morph accurately. Will I be a happy camper? Should I hold off any morphing projects until I can have this new feature? Thanks.
Attached Link: Poser 7 UI with expanded library - 2560x1600 monitor
> Quote - 1) If you only care to see 5 to 7 items at a time (as was shown in somebody's screen shot of previous Poser) then by all means shrink the library down vertically so it only shows 5 at a time and stack it vertically with the parameters. Now you have MORE space than ever before, while being able to see the same amount of content. > > 2) It is 2009, almost 2010. I respect that some people cannot upgrade their hardware due to financial concerns. But 1024x768 is not the norm anymore. I think it's nice that the UI takes advantage of the screens I actually use. Your mileage may vary. > > 3) The layout is static only if you run it that way. That's your mistake if you do that. Learn to use the UI layout dots.Good advice! - I like to have a big library open when I'm using it, then I collapse it to make way for other panels.
I'll do set up using one UI dot which gives me a 1280x800 preview window and generous room for panels. If rendering an animation, I'll stay in this UI dot mode.
If making a wallpaper, I'll set up using this same UI dot, then switch to another UI dot which has a 2560x1600 pixel preview window for rendering. The pair of UI dots are consistent in preview window aspect ratio so that camera views will be consistent.
I have similar setup/render pairs of UI dots for NTSC aspect ratio and for square aspect ratio (for making avatars and library thumbnails).
In any case, I love a big monitor with lots of room to work.
OSes: Win7Prox64, Win7Ultx64
Besides the quality of the renders and how fast they are Dependant Parameters is a totally awesome tool I've had fun playing with. As Mariner said much can be done with them.
For instance, now you can control the sway of a sword and scabbord by hip or leg movements; regardless of what body part it's parented to. And the amount of movement is controllable too!
woot!
Attached Link: tiled & procedural materials - comparsion of previews
> Quote - does it make everything look nice in PREVIEW?I have a different preview wish: I would like to see materials tiled in preview, so that I can see the effects of changes in Uscale/Vscale in real time. If not in Poser 8, then perhaps for Poser 9.
I believe this is an OpenGL issue. (?)
My 32bit Poser 7 machines with hot-rod gamer video cards preview a tiled material as if one single copy of the image were spread over the entire surface, but Galadriel (64bit, Vista, Poser Pro) has an nVidia Quadro video card, and she previews tiling correctly, plus she previews procedural textures so that I can see the scale of the turbulence pattern.
(see linked side-by-side screenshot composite)
Has any of you beta testing types looked at the file formats at all? Are there any interesting changes in there besides support for the new rigging features? For example, the ability to create morph channels from a pose file would be very nice. Also, are dependent parameters just traditional ERCs exposed to the UI, or has the ERC system be extended in useful ways?
In case people are skipping to the end of this, here's the link http://my.smithmicro.com/win/poser8/
Quote - In case people are skipping to the end of this, here's the link http://my.smithmicro.com/win/poser8/
They got it live already? One of the reasons why I need to go to bed.
Thanks Shonner.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Is it actually available now? I tried the "30-day free trial" link, and, like someone who should be in frakking bed, I followed through to the end, enabling Sm to charge my paypal in 30 days...and I got a download for Poser 7. I have Poser 7. I <3 it. I wanted to force myself to stay up all night playing with a new version of Poser.
into a fruit salad.
Quote - Is it actually available now? I tried the "30-day free trial" link, and, like someone who should be in frakking bed, I followed through to the end, enabling Sm to charge my paypal in 30 days...and I got a download for Poser 7. I have Poser 7. I <3 it. I wanted to force myself to stay up all night playing with a new version of Poser.
I noticed it too. Considering that the price is the same as version 7. Would've seen and received more info on P8 whether it'd be in a later time then grant us the go-ahead. IMO, it seemed all too soon, but I guess with all the fanfare here in the forums and elsewhare, SM's giving us the tease, I think.
BTW, with regards to the 30 day trial, I too ran to it thinking it would be version 8, I already got 7... I'm like WTF -- yeah, a classic 'gotcha' :tt2:...
Last time I looked, both the free trial and upgrade link pointed to P7 downloads. But the "Buy Now" link for the non-upgrade seemed to go to the genuine thing.
I guess I'm going to wait a few more days until they've sorted it out. It could be the real thing, and the website didn't update correctly, or it could be a leaked page that wasn't supposed to go life yet.
The Poser 8 URL http://my.smithmicro.com/win/poser8/ has been listed in 3D World for a few weeks now. You guys/gals may want to wait and see if a Pro version will also be announced.
Quote - The Poser 8 URL http://my.smithmicro.com/win/poser8/ has been listed in 3D World for a few weeks now.
So?
I'm just saying that the site is not brand new. So it may have new info added to it as SIGGRAPH approaches.
I swear it reads poser V4 or higher up grade LOL
i will get poser 8 when i get a chance
can't get poser5 to run on new PC vista 64 Geforce 9500
driver probleams
Any body running Poser 8 on PC vista 64 Geforce 9500 ?
how does it run ?
will some body post some renders of poses ?
mainly curious about how well shoulders and hips bend.
The
Artist that will fight for decades to conquer their media.
Quote - Sloppy, clumsy and irritating.
As a web developer, I kind of sympathize with whoever made that mistake. It was probably meant to go to an internal staging server for testing, and someone typed in the wrong command. As a customer, however, I am extremely annoyed.
Quote - can't get poser5 to run on new PC vista 64 Geforce 9500
driver probleams
Driver problems? Like video errors?
Quote - > Quote - can't get poser5 to run on new PC vista 64 Geforce 9500
driver probleams
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3485242&ebot_calc_page
The
Ok. That's Vista's normal reaction when UAC is enabled while installing XP applications. I thought it was something unfixable that was preventing Poser 5 from running.
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2777399
You can now see some of the nice content thats going to be included. (link above)Pinky - you left the lens cap of your mind on again.
Quote - > Quote - > Quote - can't get poser5 to run on new PC vista 64 Geforce 9500
driver probleams
Helps allot if you simply turn off UAC. It's a royal pain in the ass to have enabled.
Control Panel:User Accounts: little link there to turn on or turn off "User Account Controls" Reboot and you should be fine.
---Wolff On The Prowl---
Quote - I think this is an unasked question.
Has it been tested with Vue yet? Or will Vue need to be updated to work with Poser 8? If so, does anybody know if SM is working with E-On?
Well Vue 8 was just announced. To be previewed at Siggraph also so lets hope someone tries it!
Poser Pro 11, DAZ Studio 4.9
A way to find out way your App is erroring and what is causeing it ,, In my case it was Poser pro 7 , it was crashing after openning , moveing the camera , witch tech suport at smith mac told me that it was the vid driver was the culpret of the problems , but i had whent to vid card maker siet and updated my driver. and it still didn't help the problem, so we where stump , so i thought the tech must be right , i am doing something wrong , if i only could see a recoded history of what iteractions of the app and the cause of the problem i could then get it to the tech,,, and he would know what the problem was,
In Vista 64 you can do this it is called EVENT VIEWER
After showing this to the tech he said it defently was my video card driver that was causing the problem , so what did i do wrong, well when installed the new driver you have to uninstall the old one because it will not over write the old driver, thats what i did not do, i ask the Tech if i uninstall would my screen go black , he said it shuoldn't but go to the vid manufacture and ask them to be on th safe side, i found the instrutions on how to uninstall , and renistall and when you unistall you will still have moniter use, so being confident, followed the unistalled instrcutions, and when the computer restarted up so i could now install the new driver the graghics where smashed up at the top of my sceen in a inch strip , my word at that moment well, somthing about my pants being filled with poo, that im scrowed, but upluging the computer two, or three time it finlly cam up with the screen,where i could see it ,
It will look like it does in safe mode , just go install new driver ,
Yep Fix the problem Thank you Smith Mac tech support you rock , im soory for being a paine
Quote - Has it been tested with Vue yet? Or will Vue need to be updated to work with Poser 8? If so, does anybody know if SM is working with E-On?
On http://my.smithmicro.com/win/poser8/ SM sounds excited that Poser 8 will export to other 3D apps. But they don't mention which ones yet. The Pro version may have better exporting.
Quote - > Quote - ...or it could be a leaked page that wasn't supposed to go life yet.
This is accurate - the link posted above is to a beta page that was incorrectly staged as a live page. Our web team has been notified and will be rerouting the link.
My apologies.
I should also have added a sincere thank you for all your enthusiasm, and confirm that Poser 8 is not yet for sale.
Cheers,
Steve Cooper
Quote - > Quote - > Quote - ...or it could be a leaked page that wasn't supposed to go life yet.
My apologies.
Cheers,
Steve Cooper
LOL, thanks Steve ;) I guess I was a little eager when I saw that, and jumped on it. I should have known better, nothing awesome happens to me at 3am, LOL.
into a fruit salad.
Unless Phil changed his way of doing things pretty significantly, Wardrobe Wizard applies its own rig for any clothing you convert with it. This means any customizations to the rig you might have built will have to be redone.
My Freebies
