DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
You need ti save it in the DS-format content folder, not the Poser-format runtimelibraryprops folder. DS script files (.ds/.dsb/.dsa/.dse) are only visible in the Poser-format runtime if there is a Poser file of the same name, in which case the script is run instead of the Poser file. DS-format scene files (.daz) aren't visible in the Poser--format runtime at all.
// Load a scene file instead of a Poser file
if ( getArguments().length != 0 ) {
var sourceName = getArguments()[ 0 ];
var periodPos = sourceName.findRev( "." );
if ( periodPos != -1) {
sourceName = sourceName.left( periodPos ) + ".daz";
App.getContentMgr().openNativeFile( sourceName , true );
When you click on the .pp2 in DS (in DS3 there'll be a scroll in the upper left corner of the icon to let you know there's a .ds file there), the .ds file is executed, which loads the .daz file.
I'm having some problems creating a prop in dazstudio. I've done exacly as this tutorial says, but when I save the file in the props folder, It only creates the .daz and .png files, and when I go to dazstudio try the prop I can see the new folder but theres nothing inside of it :
I also did the same thing with poser, and creates the .png and .pp2 files, and if I cut this and paste in the daz porps folder, them I can open them in dazstudio, the strange thing is that i dont have a geometry file, can .pp2 files work without the geometry file? I've opened the .pp2 with notepad and the only files there are the textures.
