Tue, Oct 22, 7:26 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 6:50 am)
Subject: Wrought iron and liquid in a glass?
Greebo ( ) posted Tue, 28 July 2009 at 7:00 AM · edited Tue, 22 October 2024 at 5:35 AM
As the title says, I'm looking for a wrought iron shader for a set of cemetary gates. I also would like to know how to make a glass seem as if it is half filled with liquid. I have a champagne glass but it looks sorta silly with no bubbly in it.
Any help would be much appreciated :)
markschum ( ) posted Tue, 28 July 2009 at 9:27 AM
You may be able to fake a liquid by doing a texture so part of the glass is a different color , and using a transparency map on a disc or plane to make the top surface.  I use a modelling program to make a plug, that fits into the glass to be the liquid. There are also some props with morphs for level and tilt of a liquid in the glass, bottle etc .
"Champagne Flute Glass Prop" in freestuff might work.
ockham ( ) posted Tue, 28 July 2009 at 9:52 AM
I haven't been around wrought iron in a while, but if my tactile memory serves, it has a sort of waviness.  Here's one way to get there. Since this uses Displacement, be sure to check the "use displacement maps" on the render choices.
My python page
My ShareCG freebies
The result of this texture.
My python page
My ShareCG freebies
Greebo ( ) posted Tue, 28 July 2009 at 10:43 AM
Thanks Ockham, that's really cool :)
Ah, I'm not much of a modeller, but that freestuff link looks promising, thanks very much markschum :)
LaurieA ( ) posted Tue, 28 July 2009 at 5:10 PM
Quote - I haven't been around wrought iron in a while, but if my tactile memory serves,
Yes, rough and with a slight greenish tinge, believe it or not ;o).
ockham ( ) posted Tue, 28 July 2009 at 5:32 PM · edited Tue, 28 July 2009 at 5:35 PM
Interesting.  I've only seen wrought iron when it was painted black,
not in raw form.   Wonder if the hammering brings out a trace of copper,
or just changes the surface so it reflects more green?
My python page
My ShareCG freebies
bagginsbill ( ) posted Tue, 28 July 2009 at 10:49 PM
As with all dark materials, if you're looking for realism, the key will be a gamma-correcting shader, as it is all in the speculars.
Greebo ( ) posted Wed, 29 July 2009 at 1:42 AM
I took a break on the image as it really wasn't working the way I wanted it to :( But thanks very much for your help guys. It's much appreciated :)
