Thu, Jan 23, 10:23 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: HELP..Poser8 wont install
sanbie ( ) posted Mon, 10 August 2009 at 2:40 PM · edited Thu, 23 January 2025 at 10:20 PM
I have driven myself insane trying to install poser8...Is there anyone who can tell me why this is happening and why?
This is what comes up everytime I install it...
TrekkieGrrrl ( ) posted Mon, 10 August 2009 at 2:44 PM
 Looks to me like the file didn't download correctly.
The filesize should be 625 MB (655.980.276 byte)
sanbie ( ) posted Mon, 10 August 2009 at 2:53 PM
Yep that's the size and I have now downloaded it 3 times...Still it does the same thing..
Sanbie
Lucifer_The_Dark ( ) posted Mon, 10 August 2009 at 2:56 PM
I bet you're trying to run it on Vista, right click the icon & run as administrator, that fixed it for me.
Windows 7 64Bit
Poser Pro 2010 SR1
Gareee ( ) posted Mon, 10 August 2009 at 2:56 PM
Hmmm maybe right click run the installer as administrator, or make sure UAC is turned OFF if you are on vista? (google that, and you'll find complete instructions.)
sanbie ( ) posted Mon, 10 August 2009 at 3:00 PM
No I am running XP pro ...This is driving me nuts...
bagginsbill ( ) posted Mon, 10 August 2009 at 3:24 PM
When you re-installed, how did you answer the question about what to do with the existing configuration files?
jdcooke ( ) posted Mon, 10 August 2009 at 3:25 PM
If you haven't install the lastest Microsoft C++ runtime,  you can try downloading and installing the latest from Microsoft,  found here:
www.microsoft.com/downloads/details.aspx
Because the application runs in Vista, your copy of XP may require this runtime to be installed for the application to run correctly.
good luck
sanbie ( ) posted Mon, 10 August 2009 at 3:44 PM
You little beauty jdcooke...that did the trick!!
Thank You Thank You Thank You
jdcooke ( ) posted Mon, 10 August 2009 at 4:52 PM
Cool
jimmy1 ( ) posted Wed, 12 August 2009 at 10:42 PM · edited Wed, 12 August 2009 at 10:47 PM
Yes, thanks -- that did it for me too.
