Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Looks to me like the file didn't download correctly.
The filesize should be 625 MB (655.980.276 byte)
When you re-installed, how did you answer the question about what to do with the existing configuration files?
If you haven't install the lastest Microsoft C++ runtime, you can try downloading and installing the latest from Microsoft, found here:
www.microsoft.com/downloads/details.aspx
Because the application runs in Vista, your copy of XP may require this runtime to be installed for the application to run correctly.
good luck
This is what comes up everytime I install it...
