Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
I have the main Poser window on my main monitor, with everything docked, and use the second monitor for my floating windows such as the Library, Hierarchy editor, Python palette.
I have had no problems at all with this approach. Poser 8 remembers the positions of all my windows, docked and floating, across both screens.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
I only have 1 monitor but I have Poser remember where I put everything from one session to another, get it all set up as you want it then click on editgeneral preferences & choose launch to preferred state & click the set preferred state button, that should make poser play nicely with your monitors.
Windows 7 64Bit
Poser Pro 2010 SR1
Quote - I have the main Poser window on my main monitor, with everything docked, and use the second monitor for my floating windows such as the Library, Hierarchy editor, Python palette.
Pretty much same for me and no problems with display across monitors
I have the pose screen on my second monitor, and Poser remembers to keep it there no problem. The only issue I have is, when I load a scene, it never shows up in the pose window. The thing just blanks out. I have to go to the material room, let the scene appear there, then go back to the pose room and all is well.
Quote - I reported this same problem to SM, and their answer was not to stretch the app window across both monitors. (I used to press shift-maximise to do this)
Instead I have posewindow docked on the main screen and all the other stuff floating.
Works great.
Yup, same here. There's no need to expand the whole Poser window across both screens, when you can float off some of the windows to your second screen. Won't your method give you some docked windows spanning the gap between screens?
But if you really want it that way, it looks like you need a bug fix.
what I should be."
Murakami)
Right before i start i think im a lucky one in that i seam to have no real issues with P8 as it works fine.... my only gripe (and i would like to know if there is a solution) is that if i expand my P8 across both my monitor screens (as i did in P7) on closing and restarting P8 the window is now only an inch in size and only on the first monitor, not spanning across both screen as i had set it up to be.... is there a way to set P8 so that it remembers that i want it on both?
Getting old and still making "art" without soiling myself, now that's success.
