Mon, Dec 2, 9:54 PM CST
Subject: Poser8 and 2 monitors
shedofjoy ( ) posted Thu, 13 August 2009 at 5:10 PM · edited Mon, 02 December 2024 at 8:10 AM
Right before i start i think im a lucky one in that i seam to have no real issues with P8 as it works fine.... my only gripe (and i would like to know if there is a solution) is that if i expand my P8 across both my monitor screens (as i did in P7) on closing and restarting P8 the window  is now only an inch in size and only on the first monitor, not spanning across both screen as i had set it up to be.... is there a way to set P8 so that it remembers that i want it on both?
Getting old and still making "art" without soiling myself, now that's success.
IsaoShi ( ) posted Thu, 13 August 2009 at 6:08 PM · edited Thu, 13 August 2009 at 6:09 PM
I have the main Poser window on my main monitor, with everything docked, and use the second monitor for my floating windows such as the Library, Hierarchy editor, Python palette.
I have had no problems at all with this approach. Poser 8 remembers the positions of all my windows, docked and floating, across both screens.
Lucifer_The_Dark ( ) posted Thu, 13 August 2009 at 6:20 PM
I only have 1 monitor but I have Poser remember where I put everything from one session to another, get it all set up as you want it then click on editgeneral preferences & choose launch to preferred state & click the set preferred state button, that should make poser play nicely with your monitors.
Windows 7 64Bit
Poser Pro 2010 SR1
RFreise ( ) posted Thu, 13 August 2009 at 6:21 PM
Quote - I have the main Poser window on my main monitor, with everything docked, and use the second monitor for my floating windows such as the Library, Hierarchy editor, Python palette.
Pretty much same for me and no problems with display across monitors
Marque ( ) posted Thu, 13 August 2009 at 10:05 PM
Same. Did you set your preferences to remember it that way?
basicwiz ( ) posted Fri, 14 August 2009 at 1:52 AM
I have the pose screen on my second monitor, and Poser remembers to keep it there no problem. The only issue I have is, when I load a scene, it never shows up in the pose window. The thing just blanks out. I have to go to the material room, let the scene appear there, then go back to the pose room and all is well.
shedofjoy ( ) posted Fri, 14 August 2009 at 3:59 AM
it remembers where everything is but when i open poser its not expanded across both screens so i have to do this myself... and yes i did set my prefered state,lol.....
Lucifer_The_Dark ( ) posted Fri, 14 August 2009 at 4:14 AM
I think it's safe to say YOU FOUND ANOTHER BUG!!!!!!!!!!!!!!! sorry I thought it would be best to get the reactionary post out of the way as quick as possible, you should report it to Smith Micro asap.
Windows 7 64Bit
Poser Pro 2010 SR1
xen ( ) posted Fri, 14 August 2009 at 6:25 AM
I reported this same problem to SM, and their answer was not to stretch the app window across both monitors. (I used to press shift-maximise to do this)
Instead I have posewindow docked on the main screen and all the other stuff floating.
Works great.
IsaoShi ( ) posted Fri, 14 August 2009 at 8:35 AM
Quote - I reported this same problem to SM, and their answer was not to stretch the app window across both monitors. (I used to press shift-maximise to do this)
Works great.
Yup, same here. There's no need to expand the whole Poser window across both screens, when you can float off some of the windows to your second screen. Won't your method give you some docked windows spanning the gap between screens?
But if you really want it that way, it looks like you need a bug fix.
hborre ( ) posted Fri, 14 August 2009 at 2:03 PM
I go pretty much with IsaoShi, keep my main window on the main monitor and float everything else to the second screen.
shedofjoy ( ) posted Fri, 14 August 2009 at 6:08 PM
I now have my library floating over on monitor 2, and it seams to work great now....lol... thankyou all
erdi ( ) posted Mon, 17 August 2009 at 3:58 AM
I am also working on a dual-monitor. everything looks good, with the exception of the library. I do not need details. More icons would be better, like in Poser 7
Poser 8, Dual Monitor SetupPoser 7, Dual Monitor Setup
