Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
The magnetize clothing poses are for both DS and Poser; they transfer Victoria 4's joint magnets to whatever conformed clothing you're using for better fitting/bending. I've always felt that the magnetize feature does more harm than good, so I always skip the step; I even goes far as to strip the ERC out of Poser CR2's.
In other words, you don't need to worry about it :)
Thanks to both of you.
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
Has anyone here successfully used the magnetize clothing morphs in Carrara?
If so, how do you use them, and do they work well?
Do the magnets need to be specific to the mesh, the morphs, or the clothing?
Klebnor
