Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 12:52 pm)
Quote - I would check how much virtual memory you are allowing on your system. and try sreed instead of opengl. (right click in the preview window to change it) Animations suck up a lot of resources.
What settings do you have for your screen ? the color setting mainly. 32 bit or lower.
i thought it was 32 bit. everything set normally, but only when i open WMV file the colors are broken.
The colour problems with the WMV file could be either, a broken/missing codec (quite possible as it works perfectly on another machine) or broken/outdated video drivers (I have problems whenever new drivers are released & only when new drivers are released). Grab a copy of GSpot it'll tell you which codec your wmv file needs & whether you have it installed.
The Frame skipping in Photoshop could be any of loads of things, your processor being too slow, not enough Ram, fragmented hard drive, video drivers, pagefile damaged, missing or too small, display properties colour being set too low (I've had it drop to 8bit before).
Windows 7 64Bit
Poser Pro 2010 SR1
LOL.... Its the opengl caused my preview render to crush in middle of process. So i just changed to sreed!! thx, now its works normally. And, i realize my virtual memory was only around 450 of KB. Does this consider very small???
Hi,
firstly i would like to apologize if this problems are nothing to do with poser forum, but i would be glad if someone reply this... ^_^
At first, when i execute poser 7, the program works well. but when i go to material room, as i choose diffrent texture of body parts, it loads very damn slow to change view from i texture to another texture.
Second, when i render in preview mode, it can last only in range of 30-50 frames, and it crushes all in sudden. the program just close immediately.
Third, my laptop doesnt seem to be WMV format supported. When i play in window media player, the movie's colors are broken, sort of only green, blue and brown pink that kind of graphics. But when i play this movie with diffrent computer, it works normally.
4th, In photoshop, as i drag pictures up and down, there are alot of frameskip and not smooth. This also happen when i drag up and down in certain websites, especially when the screen pass thru pic that has greater resolution, or maybe high quality pics.
Finally, here is my laptop detail.
Window XP version 2002 service pack 3
im using ACER ASPIRE 4535
Computer:
AMD turion(tm)X2Dual-core
Mobile RM-75
2.20 Ghz, 2.75 GB of RAM
Physical address extension.
1 GB memory
250GB HDD
ATI Radeon Graphics
Now, Does my laptop details still not sufficient to run better???
Hope someone reply me..... ^o^. THANKS!!!!
