Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
your best bet is to have a wire frame of them done in a 3d program and add a texture to them - this is the only way i am able to pull something like this off when i need the flexibility to rotate (change direction/orientation) the object...
other wise you'd have to make a brush for each foot, and each direction/variation...
hope it helps to point you in the right direction.
retrocity
Google image search, look for astronauts footprints, then make your own brushes out of the best you can find. The larger the image you can get, the better. Best advice I can think of. That's what I did when I needed to make some footprints in snow for a project. I didn't make a brush, I made a displacement map, but same principle.
Talent is God's gift to you. Using it is your gift to God.
Quote - Google image search, look for astronauts footprints, then make your own brushes out of the best you can find. The larger the image you can get, the better. Best advice I can think of. That's what I did when I needed to make some footprints in snow for a project. I didn't make a brush, I made a displacement map, but same principle.
That's the best advice I could give too rgarding creating the brush. As per chaging the direction of each footstep, here is the solution if you own a wacom intuos: get yourself a wacom 6D art marker pen. The marker pen will allow to rotate the direction of the brush just by rotating it in your hand. I hope this helps.
Booklet printing by 10th Way
You might also google for astronaut's boots. Get a picture of the soles. I didn't stop to think that images of actual footprints on the moon might be somewhat hard to find. There's one famous print photo, I know, and may be others, but it may be easier to find images of the actual boot soles.
Is there an easy way to create boot prints of astronauts walking on the moon etc? I need these for both right and left boots and also a way to put these pointing in any direction. Any help would be most welcome.
Thanks,
David
