Mon, Feb 17, 3:54 PM CST
Forum Moderators: RedPhantom
Subject: Polygon count
A_Sunbeam ( ) posted Wed, 26 August 2009 at 3:24 PM · edited Thu, 30 January 2025 at 8:10 AM
How can I find out the polygon count for a Poser figure, (character or part of clothing)?
markschum ( ) posted Wed, 26 August 2009 at 3:54 PM
uv mapper will give you obj statistics if you load the obj.
I dont know if the poser grouping tool tells you how may polygons are in the set.
PhilC ( ) posted Wed, 26 August 2009 at 4:02 PM
The "Actor Stats" button in the Poser Tool Box will tell you.
http://www.philc.net/PTB_page2.php#geometryTools
May I ask why you need to know? Knowing I may be able to give a better answer.
A_Sunbeam ( ) posted Wed, 26 August 2009 at 4:17 PM · edited Wed, 26 August 2009 at 4:17 PM
Quote - The "Actor Stats" button in the Poser Tool Box will tell you.
It was so I could check when using your Wardrobe Wizard.
Shaun
PhilC ( ) posted Wed, 26 August 2009 at 6:52 PM
Was it you that emailed me?
Try this, open the OBJ file in a text editor you may find that the polygon count is listed in the information at the top of the file.
Or open in a 3D modeling application, most will have some way of giving you information about the model. Or as markschum says use the statistics option in UV Mapper.
Jules53757 ( ) posted Thu, 27 August 2009 at 3:16 AM
Keep it simple. In Poser open Windows - Python Scripts then click on Print Info and then on Geom Stats. The window will show you all the information you'll need.
Ulli
A_Sunbeam ( ) posted Thu, 27 August 2009 at 2:04 PM
Quote - Keep it simple.
Thank you. Found the answer.
And thanks to the other posters who replied.
S
