Fri, Nov 29, 9:22 AM CST
Subject: Making A Hole
GreenHawke ( ) posted Wed, 09 September 2009 at 1:52 PM · edited Fri, 29 November 2024 at 9:22 AM
Hi All!
Occasionally, I have made an object, for example, a box (one room house) that has been opened by placing a negative box just inside the original.  Works fine.  As I begin to add windows and doors, I end up running into one that will not work.  Such as today, everything worked, ubtil I tried to make a hole for the doorway and no matter what I have tried, I cannot get an opening.  I have ensured that the primary object is "positive" and the block for the hole is "negative".  There is nothing in the way and the primary object is grouped completely and "positive".  Any hints from you guys?  It's becoming frustrating...
Thanks in advance!
The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' (I found it!) but 'That's funny ...'
Isaac Asimov (1920 - 1992)
Ang25 ( ) posted Wed, 09 September 2009 at 2:03 PM
Any chance that any of the pieces in the group are neutral? That's the only thing I can think of that would stop it.
HTH
GreenHawke ( ) posted Wed, 09 September 2009 at 2:21 PM · edited Wed, 09 September 2009 at 2:27 PM
All of the items in a group, even if not part of the "hole" must be positive?  For example, I have a window that was placed in a window "hole" that is neutral.  It's a doorway that will not form, which I attempted after the window.  Of course, the window "hole" went fine and I simply slide the window into the hole and made a group of everything, then attempted the door.
EDIT:  I tried that just now, but I still cannot add the doorway.  After making the house - adding rooms- I turned the window I placed in the window opening positive, then grouped it and made the group positive.  I still cannot make a doorway...
Rayraz ( ) posted Wed, 09 September 2009 at 2:48 PM
Maybe your negative object is intersecting with a neutral group?
  • Lets say you have a positive cube called 'positiveCube'.
  • And a slightly smaller negative cube called 'negativeCube'.
  • Now you position negativeCube, inside positiveCube and group them, making a holow cube.
  • Lets call the resulting group 'hollowCubeGroup'.
You could say now say that:
hollowCubeGroup = (positiveCube - negativeCube) = (positive - negative)
By default, bryce now says:
postiveCube = positive
negativeCube = negative
hollowCubeGroup = neutral
  • Now you make a negative rectangle, to cut out a window, lets call it 'negativeWindow'.
  • position negativeWindow to intersect, with your hollowCubeGroup, where you want it to cut out a window.
  • Now group 'hollowCubeGroup' and 'negativeWindow', creating a new group 'hollowCubeWithWindow'.
What happens is, you group a **negative **'negativeWindow' with a neutral 'hollowCubeGroup' creating:
hollowCubeWithWindow = (hollowCubeGroupnegativeWindow) = (neutral - negative)
In this case, it does not matter that 'positiveCube' inside 'hollowCubeGroup' is positive, because 'hollowCubeGroup' shields it from any further outside influences.
The solution is to make 'hollowCubeGroup' positive as well, so that:
*hollowCubeWithWindow *= (*hollowCubeGroup *- negativeWindow) = (*positive *- negative)
Which should then result in 'negativeWindow' cutting a nice window out of our 'hollowCubeGroup'.
@Note: To simplify things you could ofcourse group 'positiveCube' 'negativeCube' and 'negativeWindow' in one group, creating:
hollowCubeWithWindow = (positiveCube - negativeCube - negativeWindow) = (positive - negative - negative)
(_/)
GreenHawke ( ) posted Wed, 09 September 2009 at 2:51 PM
Ah, YES!
Now I feel like an idiot...  I just need to be more careful, I guess.  Got it working!
THANK YOU both so very much....
Rayraz ( ) posted Wed, 09 September 2009 at 2:57 PM
Glad to be able to help! Angie gave me a good hint of where things might go wrong :)
(_/)
tjohn ( ) posted Wed, 09 September 2009 at 3:46 PM
I was going to say ungroup all groups, select all the individual objects and group them all as one group, but I think that's what Rayraz said, LOL!
Hi Ray!
Rayraz ( ) posted Wed, 09 September 2009 at 5:01 PM
Hi Tjohn!
haha yea thats what my footnote said :-P
(_/)
GreenHawke ( ) posted Wed, 09 September 2009 at 5:01 PM
As an afterthought to this topic:  Would it be a bad idea to automatically set everything to positive when I'm modeling Something in which I'll be using negative properties in order to avoid this situation?  I only ask because I wouldn't want to bind up too much memory or anything else to make Bryce sluggish.  My 'puter is slow enough...
Thanks again, all!
Rayraz ( ) posted Wed, 09 September 2009 at 5:04 PM
 I'm not sure if it will impact performance much or not.
But i guess purely for keeping things controllable, it seems only logic to only make objects that perform boolean operations positive or negative, while keeping objects that do not perform boolean operations neutral. But maybe thats just the programmer in me speaking... lol
(_/)
calyxa ( ) posted Wed, 09 September 2009 at 5:14 PM
I have a 'secret boolean tutorial' which might give you a new working strategy which can prevent some common mistakes:
http://calyxa.best.vwh.net/pearl/boolean.html
______________________________________________________________________________________
Check out my Elemental Hexagons deck, created with Photoshop, Bryce, MojoWorld, and Poser
GreenHawke ( ) posted Wed, 09 September 2009 at 5:21 PM
Thanks, **Rayraz.  It's rather helpful for latent programmer in me.
Calyxa, I read that tute.  Thanks!  Very helpful.  I had somewhat been doing things that way.  Although, I admit my work has been sloppy. - I've not been naming things/groups as I should.  Trying to break that bad habit.
Once again, thanks to you all!  Very helpful and has provided more insight for me...
jedswindells ( ) posted Wed, 09 September 2009 at 6:55 PM
This reminds me!
 One of my favourite textures for Boolean work is 'NOTHING'( Bryce grey with 100% trensparency).
  Cheers! Jed.
Ang25 ( ) posted Wed, 09 September 2009 at 8:16 PM
Glad to hear you got things fixed.
TheBryster ( ) posted Thu, 10 September 2009 at 7:29 AM
Forum Moderator
Gotta love booleans!!
50parsecs ( ) posted Thu, 10 September 2009 at 12:58 PM
Another thing to love about Bryce booleans is that you can animate them. I wish Carrara could.
You can use booleans in Carrara, but they won't move.
Quest ( ) posted Thu, 10 September 2009 at 4:09 PM
It also makes things easier and less confusing if you use different family colors for the different meshes.
