Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Jury still out. Had a scene hang up that I had rendered before. Granted that it was very high Q, and I did adjust the shadow samples, but it rendered before in 2 hours 24 minutes.
Will have to do more experimenting.
At any rate, the quality is definitely better. I did a low-Q render of the same scene, and it got rid of the neck blotchiness I had been experiencing even in the hi-Q render. So that's good.
______________
Quick note on VSS with IDL + HSV Exponential.
Set PM:Gamma to 1.
Set PM:SSS to .3 or less.
Set PM:Shine to .4.
Looks nice - no structural changes needed.
Quote - I have to agree with TrekkieGrrrl, the decimal point/comma bug is annoying as hell. AND, it's an old bug!
We got the same bug with the first release of Poser 5 if I recall correctly. It was fixed quickly with a service release and never showed up again in later Poser versions. I'm very surprised that bug is back with the initial release of Poser 8.
Other than that, Poser 8 SR1 runs great so far.
I found a workaround for this problem. I change my keyboard layout to English while working in Poser. It's not a good solution but it saves up on sanity.
Quote - > Quote - I have to agree with TrekkieGrrrl, the decimal point/comma bug is annoying as hell. AND, it's an old bug!
Ah Good idea! I'll try that until it's fixed properly!
I've changed settings, gone to factory defaults, but the problems stays.
Food for thought.....
I can't help because I don't know the OpenGL settings at all.
I wonder if starting a new thread would be a good idea. You'll get more views from people who might know what to do (if anything). If somebody finds a solution, we can link to the thread easily when others ask the same.
I'll do that and thanks for the hotfix suggestion, that worked fine.
1 h 53 mn ( phenom x4 9650 8 go ram ) only one onfinite and a square light behind the windows and a bit of reflexion refraction ...
RT bounces 2
IC 80
IDL 50
PS 3
MSR 0.2
But is there progress !
Génération mobiles Le Forum / Le Site
23 minutes on my craptop with only 2G ram and a slow dual core processor.
And my render is bigger than yours!
I had a little trouble last night. FFRender kept crashing on me. I discovered two things I'd like to pass on. I checked the Poser TextureCache (found in Documents and Settings/Local Settings/Temp) and it was crammed full with 1.7 gigs of files going back to about the last 4 images I had rendered. I cleaned this cache out manually. Number 2, I don't think P8 likes a bucket size of 16. I put my bucket size back up to 32. After doing both things, I was rendering fine again. This may not be a problem for people with more RAM. My Toshiba Satellite only has 512 megs of RAM, something I need to remedy but money is tight right now.
Weapons of choice:
This is good enough for a test render, for sure.
Bounces = 1
IC = 10
ILQ = 2
PS = 3
MSR = 2
PS, the Poser 8 backdrop has a texture causing the light shadows on the bench.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Quote - I had a little trouble last night. FFRender kept crashing on me. I discovered two things I'd like to pass on. I checked the Poser TextureCache (found in Documents and Settings/Local Settings/Temp) and it was crammed full with 1.7 gigs of files going back to about the last 4 images I had rendered. I cleaned this cache out manually. Number 2, I don't think P8 likes a bucket size of 16. I put my bucket size back up to 32. After doing both things, I was rendering fine again. This may not be a problem for people with more RAM. My Toshiba Satellite only has 512 megs of RAM, something I need to remedy but money is tight right now.
That's interesting - I'm having FF render issues as well! I discovered three folders in the User/AppData/Local/Temp/Poser/8.0 folder (Vista 32 bit) and found 1.1 Gb in the texture cache, 30Mb in an "undo cache", and 20Mb or so in a FFrender cache. Even more interesting is A SECOND PoserTextureCache that contained another 1.1Gb of temporary files - the sames ones I found in the Poser/8.0 subfolder. I manually cleared all folders - will see if the errors persist.
I also checked my PoserPro folder for cache files - both were totally empty.
Thanks for this thread - else I probably would have shelved P8 yet again.
I don't mind at all. And I think the real problem is P8 doesn't have gamma correction.
I loaded my previous render into it and applied a new "Artistic Lens" to the previous render. This uses what I'd guess should be called HSV GC.
I expect this is what we'd get from Poser Pro 2010. But since I know how to hack P7 and P8 to do GC, it's not a problem. I'll remember to do this from now on.
Quote - I'll just say the earlier render is just a darker room. :)
Just say you started to turned the lights down in the earlier render for a romantic effect with the wifey, especially with the kid off to college :biggrin:
Gary
Quote - > Quote - If you don't mind me saying so BB, those shadows are way too dark for a scene using GI. Those shadows would be impossible in reality.
whait a minute. what about tone mapping?
Quote - Quick note on VSS with IDL + HSV Exponential.
Set PM:Gamma to 1.
Set PM:Shine to .4.
thanks for this. it works fantastic.
BB do you maybe have a shader how to use images for reflection ? so that tone mapping doesnt make it brighter?
thanks.
Quote - And if i want use a 20 Watts light than a 75 Watts ? :-)))
It is now illegal for stores in UK to sell 100 watt or above ordinary glass type electric light bulbs... we are slowly being forced to use the totally useless (from a lighting point of view) curlie wurlie, odd shaped energy saving bulbs.
"You don't have to be mad to use Poser... but it helps"
Which begs the question is it legal to sell any version of Poser in the UK, if the poser lights are not energy saving? I mean IDL increases render times, which causes your cpu to run harder longer using more energy! :laugh:
Problem is someday that might not be a joke.
Gary
Quote - > Quote - I expect this is what we'd get from Poser Pro 2010. But since I know how to hack P7 and P8 to do GC, it's not a problem. I'll remember to do this from now on.
The response curve produced by tone mapping is different from the GC curve. They have some similar characteristics but they're not the same.
By analogy, if you were to go into Photoshop "Levels" and set the midpoint at 40% versus 30%, you get similar but different response curves.
Tone mapping does increase the luminance of dark colors. But the luminance of the darkest 20% are not increased enough by tone mapping. No exponent value you choose will ever produce the same brightening as GC does.
So we basically have the same problem as ever - we are forced to add more light to bring the apparent illumination to something closer to correct. At least, however, tone mapping doesn't blow the highlights. It can't - it can never produce a luminance of 1.0 or higher.
The original is the first one.
Quote - BB do you maybe have a shader how to use images for reflection ? so that tone mapping doesnt make it brighter?
Use my EnvSphere shader. It works on a plane as well as the sphere.
Set Gamma In to 2.2 for JPEGs. Set Gamma Out to 1.4. This is a compromise that I found works pretty well with HSV ETM at 2.0.
Quote - Which begs the question is it legal to sell any version of Poser in the UK, if the poser lights are not energy saving? I mean IDL increases render times, which causes your cpu to run harder longer using more energy! :laugh:
As they say... "Truth is often stranger than fiction."
In Uk... they are now seriously predicting that we will start having power black-outs on a regular basis due to available supplies v demand... in approx 10 years time.
I appreciate that other countries, including the US have frequent black or brown-outs for various reasons, but they are virtually unheard of in UK. They occur maybe once in 20 years if that. Other than when we have severe weather in some areas and that is becoming more frequent of late.
Quote - I got the SR1 and sorry to say the "Texture Not Found etc etc" problem exists.
it does? How disappointing. I guess we need to start another set of incident reports to SM. Sigh.
I wish one of these would happen to me, because then I'd probably find the cause instantly.
They couldn't fix in the previous 2 versions, I doubt they can now......
One thing which might help to discover the source of this problem is to turn on logging for texture loading. You can do this by setting WRITE_FILE_SEARCH_LOG to 1 in Poser.ini .
It will write a file in (Vista) "c:usersYourNameAppdatalocaltempposer8.0.
The file is called debugFileSearch.log.
Look at the file when Poser reports the "Texture not Found" error and look at the end of the log file what actual filename it looks for. This might provide a clue what is going on.
The only problems I have had with Texture not Found is a bad reference, but this has been the case in all versions of Poser. I use the logfile often to find which file is missing.
I have found the source of my troubles with P8 sr1 and I have fixed it.
I reported this back to Smith Micro tech Support as well:
*I had installed
Poser 8 into
D:Poser 8
Legacy content into
D:Poser 8 Content Legacy
Poser 8 New Content into:
D:Poser 8 Content New
I believe this type of folder setup is the cause of my trouble. I did it without problem for Poser 7 and Poser Pro, but it does not work for Poser 8.
I have since copied New Content over Legacy, followed by Poser 8 over combined content.
Poser 8 runs without error when all default content is together inside root runtime.
I added external runtimes on my external hard drives to library. I loaded content from the external runtimes without trouble.
*I hope this is useful for anyone like me who assumes the content need not be installed into main runtime for Poser 8.
Eternal Hobbyist
There was a bug I knew about that perhaps did not get fixed.
The problem happened when one runtime's name was a prefix of another, or the Poser main program folder name was a prefix of another. You had that.
"D:Poser 8 Content ..." is the same first 10 characters as "D:Poser 8". The bug resulted in textures not found, because it was looking in "D:Poser 8Content ...". Had you called the other folders "D:Poser8 Content" or anything else that was different, there is no problem.
You can set them up again that way - they don't have to be combined. They just have to have different letters before you get to the end of one of the runtime names.
I want to say, I am to blame for any reports that the issue would be fixed in SR1. I did not realize that the to be fixed in Version (8.0.1. ) was a default setting for the Bug Report System and those that were not fixed were updated once SR1 was being finalized to indicate a later version.
The Comma one was one I did say would be fixed and was not... if there were others, you can blame me.
ratscloset
aka John
looks good.
yes the old shaders wont work. we need to find a way how to tell poser to not use tone mapping on some materials.
and then we need to make a custom VSS shader for GI. yuhuuuuuuuuuuuuuuuu
