Forum Moderators: Staff
Quote - I was gifted these files.
They are numbered in sequence..
I don't understand how this information is relevant to the last questions I asked, so let me rephrase :-
Does either the original filename or the new filename contain a " " or a "_" ?
Do both file names have the extension in lower case (e.g. jpg) or was the original extension in upper case (e.g. JPG) ?
OK, so as it's definitely just one image, unless you find something about that image that's unusual, then there's not a lot more help I can give you.
If the image format is one that allows an alpha channel, then it's not unknown for those to be processed incorrectly (in this case a bug report to SM would be in order, but only if yuo can legitimately supply the problem image to them).
The backgound image has been Redone in Artmatic Voyager..
I have redone the scene using the same figures with different textures..
Now I render using the exact settings as before..
What do I see?
No background.
No texture on the wings
No detail on the skin..
Help..!
Preview above.
If there's a problem with that image then it's a problem in the specific format of your copy.
Once it's been through whatever mangling this forum uses to tidy up images for posting it is called "file_440349.jpg", is "JPEG image data, JFIF standard 1.01", is 242163 bytes long, and works fine as a background, at least in my copy of Poser 8.
